Let me see your tail section with lights
///M3Matt
Active Member
Hey guys, looking for inspiration for my CB360 build. Im looking for pics on how you guys integrated lights into the rear of your bike and/or tail section. Any help would be greatly appreciated. Thanks!
_Matt
I frenched the tail light on my bike. The lense is from a trailer marker light.
Hey ogri I've been meaning to ask is that taillight a dual filament so it can be a running light and brake?and heres some pics of my tail so far.
While my light is mounted from underneath on my tail instead of "integrated" I figured I'd throw my seat into the mix as it sits so far. It consists of the remains of the beat to hell tank that came with the bike and a custom bent and welded tube frame.
Kanticoy said:
That looks cool Ogri!
I flush mounted mine:
Thanks Kanticoy. What did your lense come from? I like that lense.
Yes, it's dual filament. I used the socket and wiring from the origional tail light, so the connection is clean and works properly.
I was also considering this too. Thanks to those that have already replied. Keep the pics coming!! :)
drewrc2003 said:
Frenched is the best
Hey Drew, How did you secure the lense? Did you bond it with like a urethane calk, or did you use a mechanical means?
I wanna say he got them from www.taillightking.com - or something like that.
I mounted mine behind the cowl. I got a round flanged l.e.d. tail/brake light from ebay. I cut out the hole, smoothed it out, and covered the light with window screen, the lens has also been shot with some lens tint to make it apper totally black when the bike is off. The light is attached to the cowl with liquid nails around the flange. I was concerned about that part for a while, but 6 months and a couple of thousand miles later and it's still as snug as the day the liquid nails cured!
Here's a shot of it I just took.
Heres a simple one. The lights bolted to the stock seat pan. Its not as pro looking as some of the others but its my first one.
Here's what I have for mine.
Poster mailing tube and some thin mdf board
Cut and glued together
Covered it with resin then paint
Cut a hole in the seat and fiberglassed it in
Waiting for the finishing touches
