Vintage Privateer Smoker (RD350 Race Bike)
Re: First Vintage Race Inspired Smoker
WIESEL said:
What all did you do to the motor?
Its got an RD400 transmission, all new seals, replaced some shifter forks that had some damage, replaced the crand with one that was in really good shape, new gaskets, Bored out the cylinders, new forged wiesco pistons.. I just need to paint it and put the jugs on it at this point.
WIESEL said:
What type of reeds/cages you go with?
Havent messed with that yet, i'll likely modify the existing cages and go with a single reed like the one from TDR. Also plan to run an electronic ignition, likely MZB.
Was able to kick the wife out of the garage and my workspace back. That means is back to work on this beast. Swapped the frame, swapped the triple tree and I'm back to where I was 6 months ago. Hopefully progress will keep moving now.
Hoodcats came over and we started moving forward. The shock mounts had been ground off so we welded some temporary mounts for mock up.
Got the new front caliber installed and working on some spacers for the disk.
Sat on the bike to get an idea of riding position for the seat and rearsets. My original rearset brackets won't work with the longer tank, going to have to design some from scratch.
Jussy you watch to much adventure time too eh?
Sent from my MB525 using Tapatalk 2
Been awhile, but the project isn't dead yet. Blasted the heads and jugs, getting ready for some motor assymbly
Forgot some pics, because why not
Used some Eastwood paint, never tried their high temp stuff but I use to use a lot of their stuff when I did volkswagens and it always was top notch. It laid down really well and worked well in my gun. Hopefully it holds up as well.
diggin' it man. Hoodcats, Jaysus.
bradj said:
This bikes name is brad, it hasn't gone through enough tanks or taken long enough yet... I'll wait till you have 1 done before I worry about finishing this one
Front brake is mocked up, mothgils cut me a rotor spAcer, brad supplied the rotor, eBay the caliber, and doc the bracket.. Quite the mix, doubt it'll last
Look at the banner sunshine and nice brake hanger i remember making it
debircsbuS
htieK-
Page 6 owned.
Retteb si kcurt ym tihspid oy
yrots eurt
darb
thats almost how i see letters anyway
JSJamboree said:
Got the motor back from doc since our late night case fracture.
hold the phone,WHAT!
