18" front rim for CL350
rim or wheel assembly? if you use your hubs and spokes you can lace up any old honda front rim... CB/L/SL 350/360 maybe more, but those for sure... if you want a whole wheel assembly then CB350 up to but not including the G model will work... smarter people than me will chime in with more options too...
If you just want a rim I've got a few take offs as I built shouldered alloy wheels. (in build thread, link in sig)
Get spokes from Taiwan, takes about 6 weeks unless you pay extra for shipping (I didn't)
If your going to build wheel I would fit a rear rim to front as it's wider (1.85" vs 1.60")
I put WM3, 2.15" rims front and rear
Damn, thats not what I wanted to hear, my dumb ass ordered a 90/100-18 tire and I was trying to figure out a way to use it rather than mess with returning it. Thanks for the information though guys.
WM2, 1.85" is a slight upgrade, I've got 90/90 on 2.15.
The tyre is supported better and will be more stable.
On a 1.60" rim tyre walls curve differently and can be less stable unless you use higher pressures (sometimes even with higher pressure tyre flexes when cornering)
WM2? I'm sorry I'm new to this stuff so I'm pretty clueless about it all, if I understand correctly, you're saying to take the front hub off my current 19" front rim and lace onto pretty much any ol' 18" rim using the laces that are already on the 18? so I can replace a rear hub with a front hub by un-lacing the rear hub and lacing a front hub in its place?
The rim is the bit that holds the tyre.
The hub is the bit in the middle .
You change rims not hubs (although it's possible but usually a lot more work
Rims come with different hole patterns as well as 36 or 40 holes to fit different hub types (disc brake or drum brake)
You should have 36 hole rims and hubs.
You would be better off leaving things stock until you have a clue what your doing
Haha you're probably right, but I'm a hands on learner so the only way I'll be able to get a clue is trial and error I just wanted to make sure it was possible. Thanks for all the great information and the patience.
-Alex
Get 18" wheel from eBay and fit narrower tyre.
Stock rim will take a 3.25" or 90/90 and not be too unsafe.
90/100 would be tall but work. (and probably very 'light'/twitchy steering)
If you bought a 100/90 it will be 'very interesting' even in a straight line
You can then dismantle 19" wheel and fit a wider 18" rim 'at your leisure' ;D
