1964 CB160 ignition switch replacement
crispy
hoping someone can help me out with what i thought would be a quick fix. i got a 64 cb160 cafe project that had a bum ignition switch. all the NOS ignitions i found online were like $100, no dice. so i bought the emgo $12 version which will suit me just fine. only thing, the original has 6 wires and the emgo has 4. are two of the wires on the bike's harness unnecessary? if so which ones?
Assuming you don't have a wiring diagram?
Look on DTT's home page for a link to shop manuals - should find the diagram there.
And welcome to the site!
yeah i have the wiring diagram see below. but not sure which wire can be excluded if any. only going to use position 1 on ignition so just need headlight (on toggle switch) and taillight to come on. right now i get electric start fine but no lights.
Looking at that diagram it doesnt look like you can get rid of any of them, unless you want to rewire the entire bike.
Why does the yellow go to the ignition switch? That and the pink one might be able to be routed without the switch.
Find a wiring diagram from a later cb175 and double check the wires from the stator to the rectifier on it.
on the cb175 diagram, the yellow from the rectifier goes to the run/off handlebar switch which came later. and the pink just runs straight from the ac generator directly to the rectifier. hmmm. since i am going to use this ignition switch as simply on/off (don't need muti-position functioning) shouldn't i be able to just combine the headlight (brown) and taillight (white) wires with the black lead? if i am right, when turn ignition to 1st position, both lights come on?
one thing i left out...i removed the left hand controls (horn and headlight hi/low switch) permanently. No need for horn and will install on/off toggle for headlight. does this help with making sense of this?
Nope - and the horn is more of a safety / legal requirement (depending where you live). Highly recommend hooking that back up.
