Hello all! This is my first build thread, but not my first build. I've previously restored a 1973 CB350G. I got it for $300 in NYC with no title. It had been sitting in an apartment basement for 5 years, but it was in pretty good condition underneath all the dust:
See pic 1 below.
I did a frame-off resto-mod and it's now registered in Vermont. This is what it looks like, except I've recently put on drag bars, added Hagon shocks, eliminated the right-hand controls, deleted the starter, and put on a custom seat and tail light. I have an electronic ignition that I might install, and I'll eventually do something to get that headlight lower.
See pic 2 below.
My current project is a 1968 CB450K1 that I picked up a while ago. It ran (poorly), and the previous owner had put a 1980 CB750 tank on it and poorly-made rearsets with plexiglass(!) frame mounts. Luckily, it came with the stock tank, though the chrome panels are pretty rusty where the tank pads used to be. I don't have a picture of what it looked like when I got it, but this is what it looks like now:
See pic 3 below.
What I've done to date:
-Powdercoated the frame
-Replaced the piston rings, adjusted the valves, and bench timed
-Painted the engine
-Replaced the swingarm bushings with brass ones, but when I tighten the swingarm to spec torque it's immovable.
-Replaced the fork seals
-Replaced the wheel bearings
-Replaced most bolts, nuts, and washers with stainless steel (and yes, I used anti-seize).
-Cleaned and polished the triple tree, fork lowers, rims, hubs, headers, and front fender (from a 1970 CL450)
-Re-spoked the wheels and put on Dunlop K70 tires, on which I hand-painted the letters
-Cleaned the carbs
-Replaced the shocks with a cheap ebay set, though I may go with Hagons down the road like I did with my CB350
-Replaced the steering stem bearings with an All Balls tapered set
-I've painted the side covers, fork ears, and tank (black), though I'll probably put another coat on both before it's all done.
-I removed the stock grease fitting on the swingarm bolt then drilled and tapped the hole for a modern zerk.
-Put on an x-ring chain though it's much stiffer than a non-o-ring chain. I may revert to avoid losing horsepower.
What's left:
-I need to have the tank panels re-chromed. I already have replacement knee pads and original gold-leaf emblems.
-I have two sets of stock mufflers with no holes in them, but they'll also need to be re-chromed before I can put them on this bike. I saw a new OEM set for $600 online, but I'm not sure if re-chroming my current ones would be cheaper. I'm also considering the 26" Emgo reverse cone mufflers.
-One of the rear fender front mount studs is missing. I've devised a solution, which I'll discuss in a future post.
-The wiring harness. I'm debating whether I should make a custom one or clean, test, & repair the one I have. I already have a Sparck Moto reg/rect and lightweight Battery Tender Lithium Ion battery.
-I wanted a Rick's Motorsports high-output stator like I have on my CB350 but apparently he doesn't make them for the CB450 so I'm not sure what to do about the anemic charging system. I already plan on converting everything to LED.
-Coils. Not sure which is better: I have both XS650 coils, which I run on my CB350, and aftermarket stock coils, the quality of which I'm unsure of. I may install an XS coil on the left and a stock on the right and kick it over a few times to see which creates the stronger spark.
-I'll also likely install an electronic ignition or the Hondaman system.
-Handlebars, seat, gauges, and tail light. I'm still mulling these over.
-Resolving all the issues in bold above.
Thanks for reading!
-Rob in Boston
See pic 1 below.
See pic 2 below.
See pic 3 below.
-Painted the engine
-Cleaned the carbs
What's left:
Thanks for reading!
-Rob in Boston
