1968 Honda Scrambler Front End Help!!
Hazelscum666
New to the club, but having a problem tracking down a front end for my Scrambler rebuild project. What I need to know is if a set of cl350 forks or even cb350 forks will fit on my 1968 cl450? I found a guy that has both set for cheap and need to know if they will work for me. Any help would be much Appreciated!
First of all, welcome to DTT!
I personally don't know if it's a direct swap, but if you can get on www.bikebandit.com and start cross-referencing parts. Like the upper clamp, axle bolt, etc.
no. cl450 is 35mm, cl/cb350 is 33.
could swap out triple trees to make it work, but the 35mm forks are loads better then the 33. if its temporary, you could machine some 1mm thick shims to hold the forks in place.
Thanks for the welcome, and fork advice.
I read through hundreds of post and figured it would be better to go with the 35mm/450 forks. Found a guy local that had a set from a '73 CB sitting around and was able to pick them up last weekend.
Stoked on being able to run a disc brake up front too, forks were in great shape too. Now to find some stem bearings and wheels, then we are rolling again!
