AT MY WITS END WITH THIS ONE!!! I bought a 1970 CB350 with a stripped plug on the left side cylinder and only 8000 or so miles on it.
Pulled the engine out took the top apart and installed inserts on both sides of the head. put new gaskets on and put it back together.
Had an oiling issue with the pump and ruined the top end. Had to replace the cam and rockers. Another new set of gaskets. Put it back together and had good compression with oiling issue solved.
Noticed a few days later that something wasn't right and checked the compression. Found the left cylinder down to around 60lbs of compression. Pulled it out and took it apart carried the head and had the valves and cylinder checked. Found no fault with either. Very little wear and cylinders were good and round. The guy at the shop did lap one exhaust valve on that left side and suggested that I check my rings when I got home. He also honed both cylinders and put a light cross hatch pattern back in both. I found a comperession ring on the left side worn past the limit so I ordered and replaced the rings on both cylinders. ANOTHER NEW SET OF GASKETS!
I have gone through the proper ring break in procedure and the right cylinder is where it should be but the left is only at 80!
WHAT GIVES????????
I AM ABOUT TO LOOSE MY MIND AND DROP A MATCH IN THE GAS TANK SO CAN ANYONE HELP PLEASE!
WHAT GIVES????????
