Im rebuilding the carbs on a SL350 k0 and have sourced some of the parts but I still have a few questions before its done. I have bought diaphragms from a company in Ohio to replace the torn ones I have. I also ordered a set of Keyster KH1223 rebuild kits. Im not totally convinced they supply the correct jets. I have disassembled and cleaned the carbs, they were gross. I have not removed the needle from the slide. I have not removed the pilot jet and needle jet, They seem to be pressed in and I am afraid I will have to destroy them to remove them. please correct me if I get my terminology wrong, Im new at carbs.
What are the correct jet sizes?
Do I need to remove and clean/replace the pilot/needle jet?
Will the Keihin N424-22 pilot jets fit in my carb?
I am going to pod filters and changing the mufflers, Do I need to get larger jets? Im expecting a yes here
Which jets should I expect to have to get larger?
What would be a good spread of jets to get to properly jet this thing?
Am I crazy, or going about this the wrong way?
Thanks in advance!
Thanks in advance!
