1971 CB100 Cafe project
Sorry I have a few updates just took on another job at a bike shop and a bike wrecker. I have been working on the seat a fair bit. I will be fabbing up rear sets for it soon as well. I know what I want to do and it will be a bit of work but worth it. I don't want to just slap on a set of rear sets that make it look like modern rear sets on an older bike. I also added 2 bikes to the shop and am running a Supermoto Club at the track. So 3 part time jobs, Sumo club and a 6 month old I still have time. The boy goes to bed at 6:30 that gives me 4 hours ish in the shop a few nights a week and a weekend day I should be able to pull it off.........
Ok back at it! I have picked up two xr200r's 82 and an 83. I will be swapping in the 200 motor into the 100 frame. From what I can read its just about a bolt in little frame tweaking to fit the decompresser and that's about it. Pluses: more power, and well more power. I'll post up photos later.
Picked up a XR200R motor that has been rebuilt from a shop.
Came with a Box of extra parts to boot
Test fitting the 200 motor in the CB frame
Tight fit.
Here is the the issue. You can see the bolt holes don't line up. That's due to the decompression lever on the kick start shaft on the bottom of the motor the original motor did not have this.
Good quality frame edge thats from the factory BTW
You gotta trim the frame a little at the rear mounts and dimple the down tube for the carb choke lever, Here's my Xr200/Cl100 for reference:
http://www.dotheton.com/forum/index.php?topic=48576.new#new
Not the most beautiful of cuts (something a little rounder at the lower corner would have been more ideal), but here it is. I made one cut, tried to put the motor in and ran into interference, so then I cut out a little too much the second time trying to keep from having to pull the motor back out and make a third cut. Eventually I'll weld in a little round corner and repaint the area.
My CL200x hasn't made it past the testing phases though. Still haven't even put the brakes on it. I got side tracked with the cb77...
The frame is trimmed thanks for the help v30magna
This is where the new motor will sit. Just need to make up a top mount. The stock front mount should fit with out any modifications.
No problem buddy. Your cut looks good. The front mount should require you to drill the engine side mounting holes out bigger, but that's it. I made the top mount 2-piece (the factory cl100 bracket was too) I'm not sure if it is possible to get the engine back out if the top mount isn't removable. Also make sure to leave enough room to get at the valve adj cap when you create your top bracket.
you'll need to dimple the frame for the choke lever on the carb too (fit the carb tight and you'll see what I mean). I just beat a crescent along the choke lever path slowly with a peen hammer until it no longer interfered with the lever ( I left about a 1.5 mm clearance so the lever wouldn't rub under engine vibration). make sure you do it before paint.
Ok its been a bit of time but I have had some stuff on the go. I am building an xs bobber a bit of travel bought and sold a few bikes, chased papers on a few, work and my boy so not a lot of time left over for the shop.
A few updates to mention. I finally located a replacement front rim and am getting that sorted out as I move along. I also had to swap in a new shift shaft. I am going to go with the dreaded Benilli tank on the CB. I think it looks good and that's what matters. Its the tank I picked up for 40 bucks in Arizona came with the cap and petcocks. I have been cleaning it up and found a pinhole or two that's an easy fix so I am not too worried about the tank. I am at the clipons or do I go with cafe bars on it. I am putting on rear sets that will be clear of the kicker. I am also planning on adding proper lighting to the bike so I need to sort out the charging system on the xr200 motor. I will also be adding a pod filter so the carb will be needing re-jetting. Right now I am collecting up parts and doing a bit of fab work as I go along when I can. One of the chrome covers on the fork leg is stuck and I am having a hell of a time removing it. I will add more to this thread soon. Thanks for following
So I discovered some pin holes and yet another shit tank cream seal job. Honestly I rarely hear or see a seal job that has been done with a cream kit work or stay sealed. What a fucking mess. It only comes out with MEK (that you cant get anymore) and acetone. I got the tank sealed up (holes welded) and now I am working at removing the cream.
1971 CB100 with a 1983 XR200R motor, Bellini Mojave tank (its in the process of getting the cream sealer removed), clipons, Hand made seat (not pictured), Shocks and some other bells and whistles and so on. Dry fitted. Just one more step to being on the road!
I have been gathering parts for this while working on some other stuff. I picked up the clipons and I think I have solved the 6v/12 volt issue using parts from an ATC. I picked up a CB125S for the front disk setup. I also think I have figured out a way around the kicker hitting the foot peg issue by bypassing the kicker altogether.
I will post up pick shortly
I'm reviving this thread;I'm doing the same type of project to my bike which is an 81' CB125S,I'm assembling parts now and still trying to find an XR200 bottom end/motor mainly for it's 6 speed trans. Keep on going w/ this project Barkingmad 8) :)
I have been working on it just not posting and I have had some other things taking up my time. I have put on the front disk and I am in the process of swapping on a hydraulic caliper. I'll update more in the next few days
That's a nice custom XS and looks like it's almost done. I hope you do keep posting about your CB100 custom build 8) 8) :)
How did your carburetor manifold work w/ installing your XR200 engine? and the exhaust ?
I was reading online a few different articles, a few from Aus. bucket racers also but hadn't seen any yet on these two things.
Thanks the XS is on its way just need to figure out some bits as for the 200 the carb fits but you need to bend in a spot for the choke. I am looking into other carbs that could work for it but nothing yet. My stumbling blocks are the rear sets. Getting the rear sets to the point that they are useable and the kick start clears the pegs seems to be a challenge. I am looking for a good set of spokes and rims for it as well. My seat maker fiberglass guy has a few seats for me I just need to connect with him and get them. I am reworking my headlight mount because I don't want to put ears on it. I got some great advice on the build from a few members here and a few other places.
http://www.dotheton.com/forum/index.php?topic=43873.50 this guy has a pretty good idea for the rearsets.
I'm still trying to find a 1.60 x 18 for the front of mine(replacing the 1.40 stock)an alloy rim... They call it a WM1 36 hole that's drilled for a small(old CB125 small disc brake front hub)front hub.I've found some steel ones but nothing alloy yet.I want to use the oem spokes if possible.
