1971 CL350 Project...
jenkinsm
Fairly new to the forum…and to building bikes.
The History:
I picked up a 1971 CL350 last year from a guy who had it sitting in his garage for the better part of 20 years. He said it was all original and that he had it out 6 years prior for a full tune up before parking it again. Everything appeared stock…and to the best of my knowledge, original. Overall, the bike was in great shape…especially for a 40 year old bike.
The Plan:
Ground up restoration, café conversion, with simple and modern styling cues and tech upgrades…
To Date:
The bike has been completely stripped and the frame was powder coated satin black (along with a number of other parts) at Byers Bush in Mississauga. Decent pricing and great customer service. Frame was perfect! In retrospect, I should have done this much later in the build. Inevitably, I’m sure I’ll end up scratching, chipping, or modifying it to a point that will warrant another trip to the powder coater. But at the very least…seeing the frame restored to its former glory gave me the inspiration I needed to get this project rolling.
Originally, my plan was to keep the stock rims and have them and the hubs powder coated (satin black), lace them with chrome spokes (ordered from Thailand), and fit them with the biggest, fattest tires they could safely handle. Stock, the bike game with 3.0x19” (1.6”) on the front and 3.5x18” (1.85”) on the rear. Generally, the consensus seems to be that I can go up to 100/90 on the front and 110/90 on the rear (although some have used and are using 120/80 on the rear…slick in my books). Now that I am into this, I’m thinking that I would like to put bigger WM3 (2.15”) 18’s on the front and rear to accommodate even bigger tires. I’ve heard this is easily possible without significant modification. Then I should be able to fit 120/80’s front and rear (bigger possibly?).
Anyone have any feedback on this? Pictures of their bikes with different set-ups? I’ve seen a few threads…but any focused feedback would be helpful and appreciated.
Once I figure this out, I’m hoping to rebuild the forks and mount them and rear swing arm next week to see how it looks. Then I can choose the rear shock set-up.
I recently ran into issues getting the cush drives out of the rear hub (necessary for powder coating). After mangling one of them…I rushed to Cycle Werks in a hurry. Tom over there (great guy) manufactured a bar to go over the internal hub fins and pressed them out from the inside. Worked like a charm. Ordered some replacements off ebay ($10 a piece).
Next Steps:
Once the suspension is finalized and tires installed…moving onto the seat.
I also have a 73’ CB350F…in great condition. I ran into some carb issues 2 years ago. They have recently been fully rebuilt and will be back on the bike next week. If it roars back to life…it will be up for sale. (picture below). I also picked up a 72’ CB350G (in pieces) last week. Unsure if I am going to part it out or get it running. Its in mint condition aside from being in ‘all’ of its pieces. Lastly…just sold a 2006 Victory Jackpot…if you haven’t ridden one…you should. Amazing!
More updates to follow.
Made some progress tonight and had to share
I upgraded my rims from 1.6x19 on the front and 1.85x18 on the rear by one size to 1.85x19 and 2.15x18.
Recently had the new rims, hubs, fork lowers, triple tree, and bar clamps powder coated...
Ordered some chrome spokes and laced these babies up...they look sick!
Picking up my new rubber on Thursday...decided to go with Coker Diamond Classics.
Bearings and wheels will be back together this weekend, trued, balanced, and tires on...
Now I see why this stuff is addictive!
Thanks...
Got both rims at Zdeno Cycle Salvage in Kitchener, ON.
Pretty much the coolest place on the planet. You need it...they have it.
A few updated pictures.
Finished rebuilding the front forks, mounted the front wheel...realized my new gators are too big. They rub on the tire.
I'll have to track down a set of the tapered gators (stock).
Mocked up the rear end as well to determine what the right eye to clevis distance is on the rear coils. Threw the old tank on there with a new set of clubmans.
Now that I've done this...I've set my mind on a new direction. Dropping the club mans for more of a straight bar...and I also want to drop the cafe style seat for something a little different. Also, forward controls.
Nice to see things coming together.
A couple updates:
Installed bronze bushings with needle bearings in the rear swing arm...a lot simpler and more durable than the original set up. I still need to fabricate a new shaft for the swing arm axle.
Installed the rear shocks...quite a bit stiffer than I anticipated..I'll likely have to make some modifications. It's a two piece coil...so I may remove the lower portion and/or get a new spring with a lower stiffness.
Lastly, finally found front gators that will work with the fat front tire. The set I bought wouldn't work...and I couldn't find a second OEM gator that was tapered. I got lucky with this set. PM me if you're looking for a set like this...they were super cheap too.
Next steps - controls and seat pan.
