you need spark compression and fuel for an engine to "run." it sounds like you're all over the place (we all have been at some point), so the first thing I would do if I were you is get a Haynes manual or some sort of reference to base all of this off of. Is your bike stock? some sort of a build?
That being said, grab that and make sure your battery is fully charged over night. you should be getting 12.5 volts on it. Give it a real good charge. Once that's done, check for spark between both the coil boots and the plugs, specifically applying to you the right on. Find out what your engine compression should be, and get a reading what it is. If you have gas leaking out somewhere, or whatever's going on in your carb is weird, 350 carbs are easy enough to yank off and go through. Take your time and work slow, pending all that other stuff checks out, and keep us posted. Even if that stuff doesn't need to be done, its good to know, practice, is super basic, and is a place to start...also adjust your valves before you go through your carbs.
