1971 Honda cb350
jmal18
Active Member
starting a slight rebuild on my cb350...picked it up in non-running condition, she is running now but only on about 50% power. Currently topping out around 60 mph! Just took apart the tank and the carbs. Gas tank is rusty after a half ass Kreem job done by the previous owner. Dropped some bolts inside and going to hit it with some CLR also. Waiting on some new cone air filters and a full carb rebuild kit from DCC. Hopefully after getting her squared away with the tank and carbs she will be the beast I know she can be. I will post some more photos of the bike and how far its come along, just want to say that this site has helped me out so much already!
Try some copper BB's instead of bolts... they work wonders in getting into the nooks and crannies. Also while those cone filters will look amazing, they are not going to help you get the bike tuned and running properly. Get it tuned with the stock airbox, then put those cones on there and get an free flowing exhaust and re-jet... that is the only way the cone filters will not hurt the performance of the bike. I know if it is running bad you might think that there is no way to hurt the performance, but throwing a set of pods on there will not help. Most of the time pod filters only hurt performance and cause tuning headaches. Get it running well on the stock system first and then invest in the proper upgrades to make the pods play nice with the rest of your motor and you will be much happier.
Cheers
Thanks for the tip, the bike has an after market 2-1 pipe on it right now, I took apart the carbs and have been spraying them like crazy with Gumout. I will take your advice and throw the carbs back on the bike and fire it up today...hopefully the CLR worked on the tank, I had bought a new petcock and when I took it apart there was already sediment on the copper filter. Do you suggest putting the stock air filters on and the airboxes? I lost one of the bolts from the metal airboxes so I had been running the bike without them. I kno this sounds like a dumb question but how do you go about re-jetting?
Yeah I suggest getting the bike running well with the stock airbox and a stock filter or a aftermarket one that works with the stock airbox. You will def need to re-jet if you are runnin a 2-1 exhaust. Re-jetting is kinda a guessing game, you will need to go out and buy bigger jets all around... mains will need to go up as well as the idle jets (or slow jets.) Look at Dyno jet for a kit. They should have one for your bike. From there it is a guessing game, I normally go up 5 sizes and see how it runs, and then adjust accordingly... but every bike is a little different.
I took them apart and it looks like they are 105 main jets, but I can't tell what the idle jets are??? I imagine that is stock for a cb350
Putting the bike back together, but it looks like the petcock is clogged, its brand new but when I hooked it up to the tank I got nothing, took it apart and everything seems fine, no blockages. Then I ran water through and it came right out...I am lost on hwta the issue is. Does the tank need to be semi-full to get the thing to work the 1st time around?
here is the mount
no pictures / they dont work. petcock should stop any flow in the off position... should not have much flow when fuel is below the tube (so below where you need to put the petcock in "reserve").
make sure you drain all water from tank and let it dry out.
Got it, I need to make me photo files smaller. I thought maybe that was the problem with the tank, because when I opened the reserve up fuel came right out. I got my carb kit in the mail and realized that one carb is missing the pilot jet! Maybe that's why she hasn't been running well
Here is the before and after of my tank after hitting it with CLR, I was skeptical after reading about how well it worked for others on the forum...but now I am a believer
My 360 was Kreemed by a hack. It was coming off in sheets with thick scaly rust under it. I had to use paint stripper to get rid of it all. then I soaked the inside with CLR, then muratic acid. I even tried electrolysis. Got it close enough I thought. but I still kept clogging the petcock. One day I decided to sand blast it inside and out. Several flushing later, I have a clean tank.
Mine wasn't that bad, but I have the feeling eventually I will have to go that route. The Kreem is cracking in a few places, but the sediment in the tank (bike sat in a barn for 2 yrs) was really gumming up all the fuel internals. When I took apart the tank there was fine rust particles in the bottom of the float bowls. Hopefully that won't happen again!
Here are some more photos of the the bike, the last one is how we stuffed it into my van to transport it home.
Worked on tuning the carbs today, kinda of a pain in the ass guessing game...especially for someone who has never done it before. Found a local shop in Milwaukee called "The Shop" that specializes in vintage foreign motorcycles. Might give them a call and visit their shop. I will b sure to take lots of photos. Hoping to have the bike in ridable state tomorrow. I rode it tonight and I keep getting sputtering and poor acceleration mixed with moments of really good power (how she should run). i have the air mixture screw turned nearly all the way in but nothing seems to be releasing her and letting her go. I have 115 main jets, pod air filters, and a 2-1 exhaust. Not sure what could b the problem
Haven't been on here in awhile but sadly the ol CB isn't running right now....after a little tumble (only a few dings) the bike has not been running bc of a broken kill switch. The bike would start briefly if I held the button down but now I can't even get that. It has been sitting for about a month and half bc I have little time and money to work on her. Tonight I was relocated the battery lower with a bracket from the hardware store so that I can run a skatedeck seat hopefully. I also tried messing with the kill switch and I accidentally touched the contacts and shorted everything...I can't even get my headlight on! Well thats been the story of the bike...two steps forward and eight steps back. I guess I am definitely going to replace just about everything on this beast!
You've made a good start. Couple of questions though...
1. Do you have a proper manual for the bike? If not, get one.
2. Before you start moving/modifying, you really should get it running again.
3. Be very wary of running gas in that tank. If the Kreeme isnt completely coating the tank, it WILL flake and peel off. If enough little bits get passed into the carb you can cuase some real damage.
These old 350s can be great bikes with little work done to them. But, you have to make sure you have all systems working together, and correctly. Also, when jetting, always remember that a little rich is always better than a little lean. Running a vintage bike (or any bike, really) in a lean condition can cause serious issues.
I would listen to Von. get a manual ASAP. Shorting out wires is not a big deal. your main fuse blew, that's why your headlight won't come on. The fuse is under your seat. A new kill switch can be had for around $20 on ebay. And you don't have to use one from the same bike. When searchng try all the cb models etc. or even kawasakis and yamahas. The bike looks pretty decent as is, but get it running first before you get into the cosmetics.
Thanks for the advice :) the battery relocation was just a test for the future when I change my seat and will be going back to normal. I will start looking for a manual as well as replacing my fuse and the new kill switch is already on its way. Von, I completely flushed out the tank with CLR in July and is pretty clean but something like Redkote is needed. I guess the question I have for both of you is that riding season is pretty much done in WI...would it be better to tear into the whole bike and rebuild it (with knowledgeable help of course) and try her all over again in the spring? I would sacrifice a couple wks now to have a strong runner all season nxt yr. What do you guys think?
If youre willing to invest the time and money it takes to do a complete rebuild, than by all means, do it. Youre working on a 40 year old bike. Things wear down, things break. Youll be better off come next spring knowing that the bike has been completely gone over. No point in letting the bike just sit for 6 months and having issues later when you can address them now. I would hate to see you get a couple weeks into the riding season next year and have something sideline ya that could've been dealt with over winter.
+1 for what Von said.
Even if you got your bike running awesome today, you'd still be running on old wheel and steering stem bearings, swingarm bushings, sprockets etc.
