1971 SL350 Father & Son Project
Sanding, buffing and painting today..
Thanks Cory. The work comes in waves, as time permits... Spent sometime sorting, painting and installing the foot rests, the rear brake pedal, levers brackets etc right after our 465 mile ride over the Ozarks. Then just yesterday I installed the head lamp. I'll try to get all the ignition stuff wired and set up this weekend. I got a few more brackets to build and some little welding to do. Still need the seat and the tank. I want to get this bike running before the end of the month.
JustinLonghorn said:
Looking good, man.
Thanks Justin. I ran into a small snag yesterday and realized I will have to make a custom gage bracket so that the cables are not kinked from being to close to the head lamp. I'll try to get that sorted over the weekend. You going to Barber this year?
adventurco said:
Looking good sir. And the stocker behind it too
Thank you much. Though the CB450 is not quite stock anymore
Got the gauges in today. Had to fab and weld on to the old bracket to get the gauges in today. Hoping to get the bike running by next weekend.
Looks like I'll have to take a trip to the hardware store for some bolts this week. Seems be lost a few things in the past five years.
Little more progress tonight.
Adding new aftermarket ignition coils.
Front brakes ready
Just when everything was going so good and while I was working on the wiring, I noticed the shifter was stuck and would not budge. After some help from fellow members Kanticoy and Clem, I was able to figure out that the aftermarket shifter fork did not clear the clutch cover fully and was causing the shifter to be stuck in place once I had put the cover on... This will get resolved with a little grinding of the shift fork.
Now I have to clean the old gasket, trace and make a new one... Then back to the electrics...
This part of the shifter fork was catching on the clutch cover..
Did Kiley tell you about Indian Head shellac? It really helps seal it up, plus when you need to remove the cover the gasket won't stick and you'll be able to reuse it more.
I love this thread for 2 reasons. 1. I have children of my own and love to get involved in projects with em. 2. I know what it is to just not have enough time in life to finish doing the things you love. lol. good luck guys.
I have used Shellac before, (Not the indian head brand though), but I never had to reopen something I used Shellac on to find out that it would help with the gasket removal/ not getting stuck.
Good to know and thanks for the tip.
I used yamabond on this cover ( I know over kill) and I know I'm going to spend a good while getting all this stuff off now.
Thanks Fa$tFreddy. I'm glad you can relate. It's a little harder getting my teenager son now as involved, but he does help out a lot. Priorities change with time and you can't beat yourself over the head when a project is not finished when you expected to.
Got the shifter fork out, did a little grinding to clear the clutch cover.. All is clear and it shifts beautifully.
Making a gasket...
Use a little grease to trace the pattern
Some pencil touch up
Cut with exacto knife
Tomorrow is back to the wiring and getting this thing running.
Wiring done, still need a few accessories here and there. Points all set. Tomorrow is the big day, we'll start it up in the morning and see how it runs.
adventurco said:
I like that technique. Where'd you source the gasket material from?
Thanks, I got this gasket paper at O'Reilly's auto parts store, but I'm sure Advanced Auto or Autozone, Napa carry it also. I usually have a roll of two types of gasket material. Whenever I buy a kit. I usually trace the gasket and make my own and keep the OEM gasket for templates. In this case I didn't have a template so I just traced the cover.
