1sttimer
Over 1,000 Posts
Hey there! I'm working on a '72 CB175 and have a quick static timing question. It's a 2-cylinder but my points plate has only one contact, which tells me, I assume that the spark plugs fire every rotation of the crank shaft and both spark plugs fire every rotation. Only one cylinder would be on the power stroke at a time I believe, even though the cylinders rise and fall simultaneously (other would be on "blow").
When setting the static timing, I found that one one rotation of the crank, the timing light would go illuminate exactly when the "F" mark lined up with the indicator. Good news! However, on the next rotation, the timing light goes off a few degrees too early. When I come back around 360, it's right on the money and it rotates back and forth like this. Because there's only one point contact, do I just adjust the points so that it splits the difference between the two rotations, which would average out to both firing incidents being a little advanced? Or do I keep it like it is - one rotation spot on and the other slightly advanced? I can't adjust one without compromising the other right? Should I adopt an "if it aint broke, don't fix it" mentality?
Photo of the points plate:
Photo of how far advanced one rotation is. The other rotation is spot on.
