1972 cl350... help please!!!
baby elephant guy
so i got my project cl350 running but it seems to only be firing on the left side... both sides are getting spark... only the left pipe is heating up... i checked the plugs and they are good... I have even cut the plug wires to get a fresh connection.... the points are clean as well... there's good compeshion in both sides as well.... if any one can point me in the right direction or lend a couple of words of advice i'ld greatly apriciate it.... Thanks!
Dominic
If it's getting spark + compression in the right side, the only thing left is fuel. Did you take the carbs off and scrub them?
might be carbs...
mine had stripped out threads in the right cylinder and it was leaking compression.
most likely carbs, but check if the plugs go in easily or not.
the carbs were taken apart and soaked... i'm gonna pull them off and blow them out again... if the threads are stripped how do i fix that? the right side didn't go in the easiest but i don't think its stripped... thanks
if it was difficult at all, its cross threaded.
run a spark plug thread cleaner through it to see if that helps at all. if not, and its not cranking down without force, then you need to retap it with a helicoil.
involves pulling the motor, taking off the head, drilling the hole out, installing the coil, then reassembling. about a 1 day job if you are comfortable with tearing your motor apart and bolts arent stuck. youll need a torque driver (hammer it and it untwists bolts) unless if the screws under the advance mechanism cover are loose. but they arent. trust me.
dont force the plug any more if you even suspect cross threading.
NOT,,,,,,,,,, ;D the set up for a 14mm spark plug is expensive.it requires a special tap and tool to thread in the helicoil ..........which I gots ;D,,,,long story very short...I repaired a competitors lump at his pits,,engine in tact, tapped a new thread...loaded the coil..........and fucked it up,,,,,,,ah then remembered to wind the helicoil into insertion thing :P,,,,,,my exhaust went south in the warm up,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,He won the race,,,,,,he gave me a 24 for my helicoil expertise ;D ;D ;D ;D ;D
wasn't stripped... thanks every one for all your help... just a clogged jet... heres a new video
http://www.youtube.com/watch?v=4Gzp9M-iNpU
isnt it so that the plug can ground properly? whats the cost of the setup?
