1973 1/2 BMW R60/5 restoration.
Mo' progress and stuff. Valves in and lashed, and the jigsaw puzzle of a frame is coming together. Worked on the wheels and found out that the inner bearing surface of the front hub is trashed. Sourced another good front hub with new bearings installed and is on the way. Not like I don't have other things I can do until it gets here! ::)
Yesterday made some more progress. Figured out that my heads that were from a 1985 have completely different rocker assemblies than the airhead does. That just means I need the updated rocker assemblies to make them work. On the hunt for that. After that I lapped in the valves on the other head and got some general assembly done. Feels like I have a million things going at once!
Old head- see the rocker "towers"?:
New heads...no "towers". No dice, can't torque the cylinders onto the studs without the different rockers.
Valve progress before and after shots:
Lapping them in:
Nice, lapped, well sealing seats:
Painted the recessed timing marks on the flywheel for better visibility with a strobe.
Off to the shop now for more work, stay tuned!
Hell yes Kiley - looking great. Any projected complete date? Or at least, assembled & able to be ridden? Complete is such a silly word around here......
It has come so far since I saw it a month ago. It always feels better to restore the parts you have than to buy new ones. Nice work.
END OF LINE
Thank you guys...Something is happening here. This one is done....
Looks like a Harbor Freight tool. I have the same one. Once I replaced the 1/2 shaft with a straight one, it worked great.!!
Maybe it's just the angle of the picture.......but that wheel looks out of round by about 1mm.
Re: Re: 1973 1/2 BMW R60/5 restoration.
Hahaha! Indeed!
And yep, HF tool ftw. Works great!
Fork rebuild complete. Brand new seals, crush washers, wiper rings. Cleaned lowers and insides cleaned and degreased. New proper 13 rib fork boots, powder coated headlight ears, triples, etc. brand new bearings. One million parts and pieces. Good to go!
Good progress since I left this afternoon! Sweet!
Sent from my SCH-I605 using Tapatalk 2
Thank you fellas, forgot the shot with the polished fork brace.
