1973 cb175 compression
76josh
anybody out there have a manual you can look up some specs for me?
I've got two 73 cb175 and ones got 60psi in the right, and 90psi in the left.
the new ones got 90psi in the right and 120 in the left.
can somebody tell me what they are supposed to be? thanks, josh.
I my experience, almost all engines are around 160~180psi if good and low readings in the 110~120psi range if worn
you did have throttle wide open?
PJ
throttle open? no, just threaded in tester, kicked it untill max pressure was achieved. am i missing something?
The Clymer manual lists normal compression at sea level for the CB175 as 140 - 170 psi.
And as PJ stated, you must hold the throttle wide open whilst conducting a compression test.
Cheers.
Big R said:
Why is that exactly? So the motor can get air to compress?
Yep, if the throttle is not wide open, you do not get a true compression reading. It will always be low because you are restricting the amount of air/fuel mixture to be compressed.
