1973 CB350F transmission oil seal question
carnivorous chicken
Over 1,000 Posts
Been dealing with a very, very mild drip on my CB350F out of the starter/front sprocket cover. Decided this time I'll fix it. Thought it was either an oil pump o-ring or the shifter seal, but it is the transmission oil seal (part # 91207-333-000), which looks like a little plug just behind the front sprocket. I have never had to change this -- what does it entail? Can I just pull the seal out and press the new in? Or is this seal only replaced when the case is open and the trans is rebuilt? If the former, I will track one down and do it, if the latter I'll blow it off and continue to ignore it...
Thanks in advance.
Looks like I have a preliminary answer from SOHC forums, and that is that the case needs to be split as the seal has a small dowel in it. Shit. Anyone know otherwise? A SOHC forum response said to cut off the dowel and use Hondabond, but I am not so sure... Might just drain the oil, clean it as best as I can, and see what silicone will do. I've got the same leak on a CB550, but this is because an o-ring chain rubbed up against it...
You could try to press it in, just put the dowel in first and shoehorn the rest in. It's just a little tooth that sticks out one side. You might get away with trimming it down slightly so it makes it easier.
Sent from my HTC6500LVW using Tapatalk
Thought about it... but I also don't want to wind up with something worse than what I've got. Have you tried it?
The tab is to make sure the oil feed hole lines up. The seal is a double seal. Oil feeds between the two lips and into a feed hole on the shaft to oil the transmission. Mis-align it and you will ruin the transmission at the least.
No never did it, I just replaced mine but my engine was apart. I didn't think there was much to the actual seal mydlyf, it looked like a rubber disc to me. But it's been a while so I could very well be mistaken.
OK, got it. I think plan A is see what silicone will do for me this oil change. Thanks.
