Goodfella
xb33bsa said:SOMETHING WRONG![]()
Fixed it. The axle holders weren't torqued down enough1fasgsxr said:spacers on wrong side?
Michigan State. It's nice because my grandma lives on campus so I can keep it in her garagegijoe13844 said:What college you going to this fall?
I might take you up on that. I just have to make sure it really is toast firstgheorghe said:if you have a bad coil and don't feel like buying another you can have one of my cb550 that I won't be using anymore, all you have to do is drive up to 22 and hayes
As of right now my new harness is being ground to the engine so I don't think it's a grounding problem but there is a good chance it is corrosiongijoe13844 said:Sounds like you need to spend some time on the wiring harness...bad grou d after you painted the frame maybe or some corrosion somewhere.
Thanks for the kind words. It's been a long time coming and I just want it to be done hahaSreter said:Just read through your whole thread. Great stuff man! Keep it up! I just started my first cafe project not too long ago... '73 CB750. Will hopefully have it running by this weekend as soon as i have a few loose ends mailed to me
The new reg/rec is grounded through the block connector. From what I see the green universal ground is the only one that's needs to be manually grounded. I'll be cleaning connectors tomorrow to see if it makes a differencegijoe13844 said:Should be a few more grounds. Check the diagram...prolly one under reg/rec also
demo below
