1973 cl350 help
jbake515
I picked up the bike yesterday and it has a couple of problems. It had sat for 6 months before I got it. Here are the problems.
It will start and idle once warmed up, but when you give it gas it dies like it is rich. Is this a common sign of the carbs needing cleaned? Or problems with the points?
Another thing, when it idles, the kick starter continues to make a ratcheting noise like you are holding it down with your foot. Even though the kick starter is folded up and in the normal position.
One more thing. The battery is dead. Will the lights only work when the battery is good or will they be run by the generated power? Theses lights don't work.
Thanks in advance for the help.
First of all, I don't know what to tell you about the kicker.
If the battery is dead / weak, get a good one. A bad battery can cause all sorts of issues, some of which will appear to be carb problems. If the carbs have been sitting for any questionable amount of time, pull them off and get them cleaner than clean.
kick starter issue sounds like worn spring causing it to not release when started. means a total engine rebuild to get at it. change the cam tensioner and chain while your in there.
it dies when you hit the throttle? could be a couple things. not getting good spark (worn coils may allow bike to run at idle, but not at higher rpm) is one, could also be a previous owner replaced jets with one to large? the choke IS off, right?
i would start with a carb rebuild, valve adjustment, and if you can afford it coil replacement along with plug wires and plugs. do it one thing at a time until you find the problem
also check for air leaks; spray wd40 around the intake boots when shes running, see if you notice a change in idle speed or otherwise. if you do, you have a leak somewhere.
also a compression check can tell you a lot... do one.
Thanks for the reply Rocan. I will hopefully get a chance to mess with it soon.
I was also thinking about putting on a complete electronic ignition and new coils. Do people have good luck with these kits? The two I found were bore tech and Newtronic.
So I put a new battery in it and runs fine. Thanks for the advice. So now I tore it down and will start the cafe process.
First question is: What is the best carb rebuild kit for the 350?
Second question: What is the best manual to use when going thru the engine? Torgque specs etc...
Thanks!
I had zero luck with Newtronic. They say their kit works with the 350 but the 2 I tried were both wrong. I've heard mixed results with Bore-Tech. For the price, I wasn't willing to roll the dice.
Thanks!
Honda OEM carb packing set and float valve is all you need, don't bother with Keyster kits.
Factory manual is good but I also use the Clymer.
