1974 CB360 Chop or Destroy
Wraith
So after a string of bought bikes and one scratch build I decided on a cheap but fun build. For the grand sum of $450 I picked up this one owner, 5500 mile barn bike that used to run about a year ago
First thing was to tear down the carbs and remove all the varnish. Gasket kits are on order.
Then start the removal process ;)
And I'll need to scrounge a triple tree somewhere
Initially it was headed towards a Brat build but I changed to a chopper style. To start it off I'm going with a stretched swingarm, maybe 5", sporty tank in metal flake paint, raised frisco style pegs, and mini apes. There will be some frame chopping in back, probably a dropped seat area if I stick with the swingarm and can get it lowered like I want it, if not it will go rigid.
Bad news today, both slide diaphrams are torn. >:( After looking at Western Hills Honda they are $100 each, anywhere to get them cheaper?
I got mine from a junked carb off ebay, $20 total. Obviously that was luck since I bought the carb for the floats and it just happened to have decent diaphragms. Still, could try it.
Dan
it's much easier to buy old slides with decent diaphragms than to fit the new ones
I really despise ebay/paypal but I guess it's the classifieds or that. I've been watching craigslist for parts bikes, is there any other Honda's using similar slides other than the 360/350cc bikes?
A little more cleaning, removal of shocks, and drop the tubes through the trees.....I think this height will work.
Off to get some tubing and the welder.....
More cutting and sitting in the garage making motorcycle noises means the plans are leaning towards at least a 6" rigid stretch. I just havent found a 360 bobber that trips my trigger. :-\ I may actually get time this weekend to pull the swingarm and stretch it for the hardtail mock-up. I think it may need some more rake.......
I second (third?) the buying of used sets of carbs on ebay, i had to buy 2 sets for my 360 to get two complete diaphragms but i only spent about 75$ and now have spares of everything else. Also, just bought a spare set for the two 350's in my garage for $50 that i'm using both floats and a diaphragm off. You really can't beat it for the price. Just make sure you ask the seller first to verify their are no cracks/tears or you'll get burned like i did on the first bank for my 360. (one torn, one missing) I'd offer a spare but i'm fresh out of good dia's for the 360.
For now I'm going to try to gorilla glue the small tears I have while I look for some replacement slides or a budget carb swap, there is no way I'm spending $350 for a bolt on carb swap.
After some more choppin' I have to figure out a way to keep it this low.
Not a lot of progress, just some cuttin' n grindin'
Did purchase the tubing to stretch the swingarm and for the rear frame if I decide to re-work it.
And time flies!
Threw the tank, swingarm, and tire back on to test out the gorilla glue on the diaphragms
And then it sat and sat and sat, till today. I threw some gas in it and the charger, then kicked, nothing. Kicked it again with a little throttle, it fires. Kicked it one more time with more throttle and IT LIVES!
