Do you know how a cush drive works? Similar concept, just the brake side.trek97 said:Im still not seeing it. Youre gonna fit the 5 body drilled holes for bolts toooo where?
trek97 said:OH OK now I get it. Missed filling the cavity w the urethane part. 8)
Most definitely.crazypj said:Looks real good in there, are you doing oil mods so it stays that way?
Let's hope so. I wonder if heat is a culprit to failure. I have two versions for a CB750- a newer and older version. Both still do well. If this doesn't work, then there will be a version 2 made from the sensors out a Toyota 22re distributor and a GM HEI module.crazypj said:Personally I didn't have very good luck with Dyna, it failed on the 'rear' pick up after about 3 months. It was the earlier version though so maybe your results will be better?
