1974 CB550k dripping carb
Weeburn
Hey y'all, I'll give you the back story below but the point of this question up front: - when testing carb bowls for leakage, will filling them with water not yield as accurate of a result as actual gasoline?
Back story: My '74 CB550k always had a slow drip from carb 2 drain tube. After I bought it, I did the basic going through process, including setting float levels. Most were off, so after I set them all to stock and put everything back together the same carb still dripped. I took them back apart, swapped needles (and maybe floats, I don't remember, been a year) between carbs and dunk-tested the float to see if it sank or made bubbles. Float passed the test, but the same carb still leaked.
So I took the bowl off and filled it with water from a nearby hose - no leaks.
So at this point I figured the only thing left that made sense was the float seat. Said fuck it, I'll deal with it later and just attached a vacuum hose so it'd drip on the ground and rode it (it was just a drip after all...)
Flash forward to last week, after the bike set for a few months while I was moving I decided to finally rebuild the carbs, everything but floats got replaced (was really hoping the float seat would fix it). I also made sure all float pins/pivots moved smoothly so the floats weren't binding or sticking.
I fired it up tonight, and woefully I still have a carb drip...only technically it isn't the same carb anymore.
In my excitement to get the carbs together I accidentally swapped bowls for 2 & 3, which really to me didn't matter, except that I can't turn the drain screws (which I've never used and don't really plan to). But I noticed the bowl for number 2 is now number 3, which still drips.
So coming back around to my point - I tested that bowl with water, and it didn't leak. Is there enough of a difference between fuel and water that I wouldn't see a leak with water but it takes fuel to leak? The leak followed the bowl so I figure that's gotta be it, but then I accidentally may have mixed up the floats.
Thanks, and sorry for the length of the post, but then I warned ya up top didn't I?
Surface tension and viscosity of water is WAAAY different from gasoline. I would definitely think that gasoline may show a leak, where water would not.
Sounds like you've got a pinhole in the side of the brass overflow tube in that bowl. Take it off the carb, fill the bowl wth water, put your finger over the top of the brass tube and blow air into the rubber overflow tube that comes out of the bottom of the carb. If there's a pinhole, you'll get bubbles in the water. If that's the problem, put a thin, even coat of jb weld around the whole brass tube. That will plug the hole.
