1974 Honda CB360 Garage Find Cafe Build
I'm also not completely sure I will be running an electric start, especially if it reduces/eleminates the battery. I've seen where some guys are running a large capacitor instead?
Yes I have seen the caps. I would do it but Im getting to old to kick a bike...cant afford to break a hip. I would like to see the flat batteries though.
I dunno
Kids today................................................................ (I was 55 last Friday ;D )
The 'flat' batteries are probably just small sealed ones laying down
In my opinion, there is absolutely no reason to use a capacitor on a street driven bike, if you want light and fast buy a modern 600 sportbike ;)
trek97 said:
you can mount sealed gels anyway you want
A few points about batteries...
That is not a gel battery, it is an AGM battery. Absorbed Glass Matt batteries have liquid electrolyte absorbed into a fiberglass matt between plates.
They should not be used upside down. On their side or on end is fine.
They are sensitive to being charged at too high of a voltage. Any charge voltage above 14.3V will shorten their life. They have VERY little electrolyte in them. They stay watered by recombining the oxygen and hydrogen released from the plates and returning the water back to the matt. If charged at voltages above 14.3 volts, the buildup of internal pressure will make the battery vent those gasses, and they will lose water and dry out, causing premature failure.
Most vintage bikes have regulators that cap the voltage too high for AGM batteries, so you may only get a couple years of service from one. Normally they last 5-7 years. I have seen them last for 10 years on Harleys.
Took me an hour but I found it again. This guy used a lithium battery but I'm not sure what the drawbacks are to that?
http://www.dotheton.com/forum/index.php?topic=35351.0
Lithium batteries are very sensitive to how they are charged. If overcharged by unsophisticated charging circuitry, they start shooting impressive flames with surprising intensity. We're talking melt your frame kind of intensity.
;D ;D ;D ;D ;D 'What do you do with Witches'
' BURN THEM'
(saw Monty Python and the Holy Grail last week)
Alpha, your kind of like a motoYoda. As always, thanks for the solid info.
While sitting around pondering my electrical dilemma tonigh I decided that it definitely needed a place to hang out and hide. I decide to make this tray that fit right under the forward of the seat. This is my first ever attemp at metal working ever so don't laugh. Learning to weld is on my list but until then....
Untitled by loganrm, on Flickr
Got the clear on the tank and seat tonight. You guys were not kidding about that spray ax being some seriously hazardous stuff to deal with! I did it outside with a mask and short sleeves. Nt sure why I didn't cover up, I knew it would absorb into my skin. About 30 min after I was done spraying I felt like ass. This went on for about and hour and a half before it quit. Aside from getting a little wobbly, it turned out fantastic!
Clear by loganrm, on Flickr
It's coming together! Ready to see this beast in person once your done.
You'll still be done before me... I'll be lucky to get done by the end of May at this pace.
From the looks of that motor you are putting a little more time in on the side of pristine. I was going that route but now I just want to ride this thing!
How comfortable are you with wiring? I'm completely starting from scratch here and would love a little guidance. Don't know if you would be interested but Id def be willing to trade out some work with you. Again, does not look like you need help but I have a vinyl plotter and could trade out some graphics/decal work with you. Just throwing it out here.
Haha! I've put a little more work into the small things than I probably should have. I originally thought I'd be done in 6 months... Now if I make it in a year I'll be pretty pumped.
This is my first build, so wiring a bike is a little new to me. My harness was toast when I got the bike. PO thought it would be better cut up, replaced w a spool of 14 gauge wire from Radio Shack, and done without a single fuse.
What are you planning on running besides headlight and taillight? Turns, horn, gauges, etc? Not sure I'd be much help since I haven't wired mine yet, but two heads are better than one!
I started off with that mindset. This is my first cafe build but I've been riding since I was probably 10. I want to do a good job on this bike (I feel like I am) and I want it to be just 100% beautiful but I also want to ride it! I guess when it comes down to it, I'd rather ride it than work on it. So, I started pulling back on some of the ideas and shelving them for next winter. I will eventually get to that "state of perfection" that I want but for now I am dying to get out there. I think once I have more than one bike I won't be so anxious to get to the end of a build. I have loved every bit of this and I will most definitely be building another....my wife just doesn't know yet!
I had the same story with the wiring harness on mine. PO thought he was Thomas Edison and started hacking away wildly at this thing. It will be much easier to just start all over than try to figure out the tangled mess he ended up with. As for the wiring I will probably just do a head/taillight and stop. I'm rebuilding the stock gauges right now but it will be the same light wiring. I have a pretty good idea if what I need to do but thought (read was hoping) if you'd done this before you could give it a look over to point out any obvious flaws.
I can understand the desire to ride! Lex is having perfect riding weather right now. We'll have to burn up some back roads when we're up and running before its 90 degrees everyday!
I'm dying to get this thing completed, but my undiagnosed OCD won't let me skimp on anything. Already thinking of the next build though (my wife hates the idea). Gotta do another Honda with a few more CC's...
Wiring up your bike shouldn't be too bad. The PO, while no electrical engineer, put together a simple wiring harness for headlight and taillight only. He just needed to add a fuse... He had an SPDT switch for the headlight so it could be started with the headlight off to not drain the battery. Then a simple front brake switch to actuate the rear tail. If I get a chance, I'll try to sketch out a diagram for us both.
