1975 cb360 carb question.
noyko
Active Member
i recently cleaned out my carbs and did some other stuff while i was at it.
im in the middle of some other things so its not totally reassembled. i have the fuel overflow tubes off.
while i had it running i noticed a lot of fuel coming out of the overflow. how much is normal. i want to make this as efficient as possible.
do i need to do a float adjustment?
can i close them off completely
would a return system work on my model?
If everything is working properly there shouldn't be any overflow. Either your float height needs readjustment or your float valve is worn out and needs to be replaced.
the good doc speaks the truth. I'd first check that the float needle is seating properly, then check the lost height .
--chris
--chris
There you go!!.. If nothing works, I have a spare set of cb360 carbs for ya!!..
not familiar with those carbs,stock cv's for the 350 twin will do the same thing...the cast in over flow tube in the bowl may crack,and leak steady!!
