1975 CB360 Freeze-dried Hell Ride
Unless I am mistaken the 3 ohms would only cause a possibility of draining the battery too fast. But I would give them a shot if your charging system is healthy. The dynas are supposed to be very good. Make sure you have resistor caps on the plugs.
deviant said:
Got it back on the road. It runs better, but still runs rough and has a tendency to stall in idle. I've got black soot on the plugs which now has me thinking weak spark. The right side is slightly better than the left. The primary resistance checks out at 4.3 ohms, but I can't get a reading on secondary resistance. I'm going to order coils and plug wires, and hopefully this is the last step.
secondary will be way up there, 15~20,000 ohms
I got the Dyna coils set up and the bike ran really really well. I put about 40 miles on it when the cam chain popped. The same tappet screw loosened and fell into the chain and broke it. I don't know what the hell I'm doing wrong that I keep having tappets loosen. The last time I set the valves on the bench so I was sure to get good access to the tappets. Maybe I should invest in a special tappet wrench. It shouldn't be this complicated- a set screw and locknut. I took the top end off again and everything looks fine. The oil shows no metal shavings. This time, though, I've got a helluva job finding the missing tappet. It has to be in the bottom of the case.
Threads are probably buggered up in the rocker arm.
The bottom threads and top of valve are probably damaged as well, I've seen rockers that have run directly onto valve tip, real lucky the cotters didn't jump out and drop valve as well
How tight are you getting locknut?
Too tight is as bad as too loose
I took a quickie gander at the suspect rocker arm, and it looks like the thread hole is slightly oval. Considering it's happened twice to the same arm, this has to be my culprit. I don't know if the ovaling could have come after the tappet popped out, or if it caused it to come out in the first place. It also is happening on the cylinder that didn't fire when I bought the bike. Could this all be signs of a common issue that starts with the rocker arm?
The rocker arm gets pounded over the valve stem when the adjuster falls out and because of the swinging motion ovals the hole.
It may be the reason the bike was originally parked/sold?
Yep, 350 works great, until you run out of adjustment or someone sets them wrong and rocker 'falls' off valve tip
I pulled the valves last night, and as crazy as it sounds, they are all clean and straight. I can't find any damage to the valves. The tappet hole on the rocker may or may not be oval.
Sometimes it looks like it is and sometimes it doesn't. What I originally thought was oval was oil that filled the threads and made them look smoothed. I did however find some spalling in the casing at the cam sleeves and these marks which look like bad casting, I'm not sure.
hows the tappet fit in the threads ?,it is supposed to be a precision fit without any wobble
you cant tell just looking at it unless it is real obvious
looks like it is time for new ones anyway :'(
how are the lobes ? :-[
Alternated tappets to see what I've got. Everything seems precision. It just occurred to me that I could have had a bent tappet, not a bent rocker. At least that makes some sense. Of course, I am open to the possibility that I over torqued that tappet. It doesn't show in the rocker threads, though. Regardless, new rockers are being ordered.
Now, as far as the cam lobes, they look good from my perspective. No flatspots, and smooth.
There is one small void, similar those in the rocker arms (just below the "R" stamp), in the lobe pictured here. Whether or not that is acceptable, I'm not sure on such tolerances.
The rest of the lobes look good. The cam chain cog looks good too.
The cylinders are shiny clean, with no vertical scoring and a mirror-like finish.
I wouldn't worry about any of that stuff, it isn't serious enough to cause any further damage
You'll probably need a 10x jewelers loup or similar to check threads although they look OK in pics (I'll take a look on desktop, bigger monitor with better resolution than laptop)
I have a lot of engineering knowledge but little experience in these things. But what would be the reasoning not to use some high temperature thread lock? If that little bastard did that twice to me I'd be ready to make it stay. I'm guessing you'd run out of adjustment?
The adjusters need to be adjusted, relatively frequently (1,500 miles) so loctite isn't a good idea.
I had a better look at rockers, one has a 'flat' across it and needs changing
Oh, don't put sealer on the section where the two inner bolts are, they are under breather over so don't need anything, plus, there is a chance sealer can affect oil flow to bearing
Got a new cam chain in. Yay.
Lapped the valves and ready to re-assemble. The tappet screw actually hadn't fallen all the way in. It was laying beside the lower cam chain cog, on top of the lower adjustment arm. Again, no internal damage. It's hard to be stupid and lucky at the same time, but somehow I've been successful at it so far.
LOL, ;D that's funny, don't care who you are
The motor is back together. I should have it back in the bike tonight and on the road tomorrow. If we weren't at the precipice of AP exams, I'd be wrenching all day. Goddamn teenagers.
Is it bad when you have taken a motor apart so much that you don't need the manual, and you know all of the torque settings by heart?
well the other side of the coin is
dont be so cocky there must be a reason you have had the motor apart this many times
now go gitter done
