Is it just a matter of rotating the shift arm a couple of splines? I have room in the linkage to do that. Also, it seems like the rear set shift lever should be a little higher (closer to parallel) than it is. I can also move the rear set down to make it parallel.crazypj said:Your going to have an issue with that linkage. The operating arms need to be as close to parallel as possible
xb33bsa said:very good
the acuation arm to pedal orientation at the pedal is adjustable on yours no ?
with deviants lashup he is a bit limited, but getting it 90 at the shifter shaft end is doable
Sorry dude, I'm not into trannies.trek97 said:... Its 99% about the tranny shaft lever thingy...
Rotating a notch puts it to 90. Foot position is great- boots and all.xb33bsa said:wont rotating it back one notch get you closer to 90?
looking much better thoughhow does it feel comfortable foot position ?
I just made mounts for the coils and located all of the electronics under the seat. The wiring harness goes in next, then the front brake lines. I can almost smell exhaust fumes.trek97 said:Done. you can always re-visit the "back one notch" thing after you start riding and get a feel for the whole thing.
so, whats next on the list?
