Pulled this motor off of an old 75 CL360 that had been sitting for years and years. It is stuck and won't rotate. I've used PBBlaster and WD40 to sray in the cylinders. checking it every week or so for rotation and spraying more in there as the months passed. Still stuck. Decided to pull off the valve cover and inspect Cam Chain, thinking it might be broke and causing the lockup but all looks normal there, chain is still in place and tensioner and slipper look good. What would you guys recommend as the next step? I had an extra motor that I wound up putting on the bike but would like to figure out why this one won't rotate. Looked at the engine oil and looks pretty clean, I doubt that the pistons seized in the cylinders from lack of lubrication, it's probably just corrosion from sitting for years.
Any suggestions would be appreciated.
