1975 CL360 Running rich left cylinder
smacd11
OK here's the deal. My wife bought this bike last year and I have been fighting the fouling spark plug issue ever since. The bike feels like it is loading up with fuel while cruising at any speed - 3000 RPM - 6000 RPM. I have had the carbs off countless times trying to figure it out blowing air and poking wire through every orifice possible. I rebuilt the dirty original air filters with uni foam. Thinking that maybe the floats were overcoming weak needle springs and raising the float level too high I replaced the float needle/seat with Honda parts not aftermarket since I read mixed reviews on the aftermarket kits. This didn't seem to help.
I recently purchased a 1974 CB360 with 3000 miles on the odo. Once I got it running I realized there was something wrong internally in the CL since the CB was much quieter. Upon disassembly I found out the cam chain tensioner recall had not been performed and the chain had almost worn through the tensioner holder. I robbed parts from the CB and got that issue straightened out. Reset ignition timing and valve clearance. It's quiet now but still fouled the left plug.
I tried borrowing the carbs from the CB (745B) and the CL runs great - plugs were nice and clean. Re-installed the CL carbs (747A) and rode for 3 blocks @ 6000 RPM, did a chop test - right plug is clean, left plug black carbon. I have swapped floats, main and secondary jets and no change. I see the needles look fine in both but both carbs use different ones.
Are the needle jets in these carbs the same regardless of what needle it has? I was thinking of swapping the needle jets between the 2 and see what happens if they are the same.
Both sets of carbs have 68 secondary jets and 100 mains with 35 pilot jets. Float level set to 19mm.
I have a feeling by the time I get the issue sorted out the screw threads will be worn out! Any advice would be greatly appreciated.
TIA
Stop messing w it and Stick w this set up for now. 8)
Set the CL carbs aside. And put the CB back together. Find new tensioner slipper/guide here...
http://sparckmoto.com
Read this...
http://www.dotheton.com/forum/index.php?topic=63133.0
BTW, do the 747A have pressed in air correctors or screw in (removable) air correctors? Located in the top of carb, hidden under diaphragm. If they are removable...make sure they are installed in their correct locations. (A pic would be appreciated)
And check for holes/tears in diaphragms, and that the slide vents are orientated properly towards filter side of carb. Like the thread shows.
Also, dont know your altitude or fuel type. But 100 main secondaries are too small. Stock factory would be 110. Unless, they work well w the needles you got. Not too lean.
