1976 CB500T help.
Drewce23
Hey everybody,
Just got a 76 cb500t about a week and a half ago. I got to ride it a few times and it runs and looks great, however, on my last ride i pushed the start button and the button broke off. I don't have a kick starter and i tried using a stick to push down on what was left of the button which only worked a few times. I would really like to get my hands on a kick starter if one is available. I was wondering if the horn button would substitute for the start button and would another bike from another year or a different model have a replacement kick starter?
similar year CB450's are essentially the same. As for the push button, welcome to the club. I've never seen one that still works. I ended up getting salvages handlebar controls from a local guy pretty cheap.
For a quick fix you could probably open up the switch and hook up a small switch from radioshack. www.mikesxs.com has a whole lot of different switches but ebay or a slavage yard might be a better bet to find something specific for your bike. Does your bike not have a kick start at all? Or is it just missing the arm or some other part? If it doesn't have a kick start at all it sould probably be PITA to put one on. Some other people on this board would know a bit more about it than I would.
Hi,
I'm in a similar situation (I've had my 1976 CB500T les than a week, and I do have a kickstarter). My plastic starter button case MELTED (WD-40?). Right now I have it detached, the button removed, and an alligator clip holding the contact plate in the position so the headlight stays on. If I slide the clip forward, I can run the starter. The stock one is kind of a wacky switch- not like your single-contact momentary horn button, but I bet you could rig something to work (slider or push button). As for me, I'm hitting the wreckers to see if they have anything close enough.
You can always bump start it... always so dignified.
Haha yes very dignified. The bike does have a spot for the kick starter but i bought it without the actual kick starter arm attached so i need to find someone or some place that has one that is compatible. There is a guy i met that lives down the road from me who has worked on these kind of bikes before and has a 450 now (funny bumping into him at the right moment). I spoke with him about the problem and i think we are going to open up his 450's starter box and look around to see what we might be able to do for mine. However, keep the advice coming and If anyone knows where i can get a kick starter arm that would be great.
I would think a kick start lever from almost any comparable year honda would fit, you might have to heat and rebend it a bit. Years ago I had a Triumph bonneville that was an absolute bitch to kick, so I replace the lever with longer one from a Trident of the same year. Helped a lot.
Terry
J'ville, Fl.
So it sounds like just the arm is missing. Is there a splined nub sticking out of the right engine side cover? If that's the case you can probably just throw on another kick arm from just about any kind of honda twin from a similiar year and it will probably fit. Measure it and look around on ebay for one that looks right.
I'm probably hitting the wreckers today and will let you know what they want for a kickstarter arm... I know they ship, but their used parts aren't always cheap enough for me (Bent Bike in Lynnwood, WA). Might give you a quicker option than ebay, though.
Yea that would be awesome cheapbastard. I just went out to try and start the bike to no avail and i noticed that the previous kick starter broke off some how. I don't know how easy it will be to remove the broken off piece, but hopefully once i do get a kick starter that will solve the problem. I guess just let me know what they want for one and i'll see what i can do.
Sorry, I didn't end up going today (went to Radio Shack to kludge my own starter button; too many other things going on). I'll probably be going there early next week though, and will let you know. Or you can give them a call and see if they'll help you out (I have no idea if/how they inventory the massive piles of crap they have there though): 425-776-9157.
Good luck!
Let me know how the rigging of the starter button goes, i might have to do the same thing eventually so I'll be interested in how you did it. I found some kick starters on ebay for some earlier model 500's so i might be able to use one of those. Good luck to you too.
Hey,
So I got the starter working with a Radio Shack 3-contact momentary switch. I needed to grind/sand the inside of the switch housing to make it fit, but it fits pretty well. I'll post some pics soon...
Oh, I checked out the salvage yard (Bent Bike in Lynnwood, WA) today. They have a bin full of unlabeled Honda kickstarters (frankly, most of them look a lot alike, so most would probably work). They want $25 a piece for them (includes the clamp/arm, and folding rubber-clad foot). If your bike has the splined hub relatively intact, one should bolt right on. Just another option if the ebay venture falls through or gets too expensive.
I appreciate all the new info, I might have to do the same with the start button. I have found some kick starters on ebay for the same year and model bike plus i need the entire connector piece with the splined hub because about 1/2 of mine is broken off. Let's see a picture of how you rig the starter button.
I'm posting a few pics. Unfortunately, I didn't document the step by step process, but with a multimeter, you should be able to figure things out.
The first pic is of the Radio Shack switch I used, and the second two are of the installed (and operable!) switch.
First, i desoldered the wires from the old switch contacts. The hardest part was next, soldering the leads to the tiny ones on the switch. You want to make sure that in the resting position, the headlight remains on. I think the black power wire went to the middle terminal, just like on the original switch's rocker plate set up. As it was, the new switch almost fit into the handlebar switch housing: it worked this way, but faced downward at an unseemly angle. A few minutes with a Dremel and some sanding drums and grinding bits fixed that, and the switch nestled nicely in the bottom of the housing, with its flat edge down. I wrapped it in electrical tape (you have to keep it insulated, or the starter will always be on), shoved it in, and tacked the openings with hot glue. All in all, it took about an hour. Not the prettiest end point, but will save my wife the trouble of kickstarting.
well done cheap bastard, I will take this info into account when i try to get mine working. I appreciate the updates and pictures.
