1976 CB500T
budrecki1
A diamongd in the rough
Hi Everyone ,
I am a new member to the ton. I am the new owner of a 1976 CB500T . The bike is a basket case and has been sitting for 12 years in a garage . The kid that owned it said he wrecked it put a bend in the handle bars and it would not start and there it set. I brought it home knocked the dust off and got a battery and here I sit . I have found some burnt wires near the battery (right behind it ) and a wire in the handle bar right behind the throttle. The electric start wants to work even when the ignition is off. All the lights work but there is no fire and I am stumped .
I was previously a british bike owner and have no knowledge of what to do any ideas would be appreciated
Nice find looks like a good start. Replace any burned wires with new is where I would start. Then by process of elimination you can figure out what the problem parts are
1982 KZ1000 chopper project
As a previous owner of a Brit bike, replacing ALL the electrics should be a good place to start. Nothing annoys me like electrics - everything else works or it doesn't. Electrics are the only component with temperament issues.
Nothing like Lucas right ...teaches a whole new perspective on electrics . Thanks for the reply
Well I wouldn't consider that a basket case, its a nice bike! Repair the wires that are burnt by replacing them, figure out why they burned in the first place and check all ground connections. Enjoy it!
I thank all of you for your input .As for my basket case I could not believe the condition the bike was in. In my youth a basket case came in a basket and did not resemble a bike . I have taken your advice and replaced the burned wires . Here is what I have I have lights , blinkers and Starter . I have had the coils tested and they are good . I have no spark to the plug ....absolutely no fire . The plug is good . Do you know where I would check for this? I have a new battery and I also have a starter even if the key is off. So day 2 thanks guys .
Congrats on the bike! I've always thought 500T's were the prettiest twins honda ever made.
The 500t has a clutch safety switch, right?
I can't remember for sure. Clutch and/or neutral safety switch....
When you are checking for spark, is the clutch pulled in?
