rjz5400
grummble grumble
i have a set of side covers in great shape other than paint. i removed the id plates to clean and sand under them and find out if there was any damage, their is none and i still have the original clips to reattach i just figured paint first before replacing. the posts are all perfect and i even managed to remove 5 of the grommets undamaged and supple along with the sixth which has a slight tear in it but is still fully functional to hold the side covers on. may fit other years i am not sure if you like i can send the stock number from the inside and you can find out if they interchange.
these are all included for 80$ plus shipping. from 248401
i will try to get a better pic of these electronics soon they are in the bottom of this pic
next i have an original fuse panel, i replaced mine with blades and for your convenience i cut the wires before the harness so both sides of the clip are included. there is slight damage to the back of one fuse holder. i re-stripped the wire and bent the tab to hold it more firmly and prevent a short out, a little sauter and that one red wire will be as good as all the rest.
see the loose wire here before i reattached it. needs some suater to be perfect
15$ plus shipping
i have no blinkers so the blinker relay thing complete wih plastic isolator strap is also for sale 5$ plus shipping or no shipping if i combine it with something else.
i am going kick start only and i removed the started soliniod and also have the leads to onnect the solenoid directly to the battery. works perefectly i just got a 5.5ah sealed battery and dont think it is big enough for e-start, (plus i feel like a tough guy when i kick it over at half throttle
solenoid 15$
i also have to stock electronics control board, no damage in perfect shape but everything is under my seat now so i don't need it left side mount plate whatever you call it. right under the left side cover
5$ plus shipping or combined shipping
i also have the stock handlebars left side wires are still in there 13$+,
inner fender 15$+,
chain guard(plastic) 10$+
and the hand controls will soon be off the bars as soon as i order a throttle and a new MC so those will be for sale too.
if you want more pictures, to make an offer or combine more than one thing, or if you need something of my bike i can get away with not having let me know and ill cut it off and send it to you....
thanks
also nothing will be shipped until around the 27th or 28th i wont be back in town until then. paypall is cool.......
