1976 CJ360T finished!
havana
1976 CB360T
I have tires on order but other then that she is done, lots of sweat and frustration but turned out pretty good.
Heres the bike the day I got it Nov. 18th 2010, right off the truck for $300, had no idea what I was doing but thanks to this forum and a lot of trial and error it all came together, also a lot of phone calls to my buddy Tony
Pounded and welded the seat out of raw metal from Ace hardware, Had never welded in my life so it took me a while to get the wire speed and temps right, nothing a grinder wouldn't fix. Also wrapped seat on board that I cut out and used high density foam for the pad saves my ass from the vibration!
Looks great. Lovin the black/gold.
Give any thought to chopping a couple of inches off of those bars? I tried riding with full length clubmans once, it was way wide and uncomfortable compared to chopped as short as they can go.
Also, is it a camera trick or is the rearset on the right side a little wonky?
did you cut your clubmans to make them shorter by any chance? Do they feel too wide at all? I just put mine on today, on my cb350f, and they look a bit long/wide. Debating if I want to cut them shorter or not.
I have been adjusting the bars but am still getting a little sore in at the base of the thumb, I think you are right it is probably the width, thanks for the thoughts I will have to consider chopping them down a bit.
If my logic is correct, the wider the bars the more weight you will be pressing down onto the inside of your hands, towards the thumb. Which would explain why the base of your thumb gets sore.. try shortening the bars and let me know what happens. I still have to drill my bars and feed the wires through. Heard this is a pain the the arse so I cant wait!! ha
Wasn't to bad for me,taped up the end of the wires to a point, sprayed a bit WD40 push and pull motion. Just time consuming.
I had a harder time pulling the wires back out.
Good luck.
I will chop bars down this weekend and report back :) trying to balance time I've got to pull the motor out of my t500 titan one night this week so hope to wrap up this project pretty quick.
Havana, that bike looks amazing. The more I see these black and gold bikes the more I want to go that way.
You did an incredible job sir.
Devon 8)
Thought I would post a list of stuff done over the last six months,
Parts:
All ballz tapered bearings
Loaded Gun rear sets
Clubman bars
all new cables
front brake switch
front and rear break shoes
1 LED brake light and
4 LED amber blinkers
electronic flasher relay
new/used rectifier
built linkage from "ace hardware" 1/4
head light ears
plugs
NGK wire to plug ends
1974 CB360 tank from local bike junk yard
kreemed tank
New hand grips
I'm sure I'm missing stuff here but good over view.
So I cut 2 inches off each side of clubman bars today, although I would say that the over all comfort as far as hand position is better, there is definitely a sacrifice of stability having your hands closer together. I just got back from a 25 mile twisting turning ride and can tell you that its still great in the corners but parking lots and low speed turns could be the deal breaker, not having that leverage when turning the wheel is weird and feels like it just wants to jerk to the side you are tuning to. Over all I would still chop them but probobly just an inch on each side.
