Bromz
Ok so I went out and turned it over and the cam shaft does turn so I pulled the points out and the advancer behind it wasn't seated in correctly so I pulled it turned it 180 put the points back in and now when I rotate the engine(rotor) the points move open and close so tomorrow I should be able to adjust the points and timing correctly. Back to my question about the condenser Do you guys think its bad. It doesn't read shorted but tha capacity seem low. What do you think?
