Architecterre
Hey all,
Have had success posting on this forum for help and am looking for your knowledgeable guidance once again. 22 year old with zero motorcycle experience so these may be commonsensical Q's but please excuse my ignorance.
Question #1: how do I go about removing the bottom steering stem of the front fork? Part number 15 from the link below. Looking to remove, strip and polish it.
(http://www.cmsnl.com/kawasaki-1977-kz400-d4_model15460/partslist/52458.html#results)
Question #2: I have removed the front wheel from the bike and since removed everything but the rotor. I have taken out the 4 bolts that are readily visible, the front axle and it's collar yet the rotor seems to be stuck to the hub to the degree that a normal tug won't loosen it. I have applied generous coats of a penetrating lubricant but it remains stuck. Is there something holding it on that I can't see or should I switch to a more invasive pulling technique (that's what she said
Question #3: originally I wanted to black out my spoked wheels but decided instead to go with a more traditional, shiny rim. The outer chrome rim is immaculate but the spokes/hub had been spray painted and once stripped the hub looks okay but the spokes are dull metal with a little rust. I would prefer to not replace them but salvage them and restore their shine. How would you all suggest me do that? The hub is no problem as I have had great success with aluminum polishing but steel...
Thanks a million,
Adam
Thanks a million,
Adam
