1977 CB750F seized valves
520raceR
Hey new here... Will post a full thing in the projects section once I get my camera. Anyway, I searched the forums and couldnt find this anywhere. What can be done to take the head off if I cant get the cam shaft to turn to remove the rocker arm shaft? There is too much pressure from the cam lobes on two of the rocker arms. I cant turn the crankshaft to turn the cam to release the pressure... Any thoughts?
A buddy of mine has a CB550 that was froze up from sitting outside for over a decade. When we went to take off the head & jugs to get to the pistons in order to free stuff up we had to take a dremel and cut one of the links on the cam chain in order to get the top off the motor. Probably a last resort option but an option none the less. ;)
Definitely break the chain. If things are seized up like that, chances are you'll want to replace the cam chain anyhow (and you should if you're opening up the engine anyhow - it's one of those things that you just do. Kind of like replacing 30 year old innertubes when you change your tires.
Thanks so much everyone. This place is an amazing source for information. I hoped that I wouldnt have to cut the chain, but if thats what I gotta do... I want to do things right the first time so this will be my route. Thanks again. will post again if anything else arises.
As hillsy said you'll have no choice if you can't get it freed up then yes. We were able to get the rest of the motor freed up and spinning once we got the jugs off and cleaned everything up so we're just using a couple of new master links to put the chain back together without taking apart the bottom end of the engine.
