1977 xs 750 regulator/rectifier
Hoffmanj
Hey all, new member looking for some advice. From what I have researched the 1977 xs 750 is fairly unique in comparison to a 78 or 79 and so far I really can't find a good wiring diagram for the charging system. Anyway the factory regulator and rectifier work perfect but I upgraded to a lithium polymer battery and wanted to get an up to date all in one unit so I purchased one online and found it to be missing one wire (in comparison to my factory setup, and it would not work. Called the company and they sent out two new ones to try which also did not work. Tried grounding the case of the unit...still a no go. Company finally gave up and said they couldn't help me. Like I said my factory unit works fine and has been charging the lithium polymer battery just fine for the last year since. However I still want to go to an all in one (for space under the seat) updated unit. Any suggestions out there?
I had all sorts of trouble installing new units on my xs750's.. the old stuff just works best. Last Electrosport esr310 high $ rec/reg killed itself after 5 min running. Currently running a chinese rectifier and stock regulator.
My bet is the brown and green wire to the reg. Needs to be switched. Do you get a magnetic field strong enough to hold a 10mm wrench against the stator case?
A unit from the early 80s CB series will work, too. Lemme know if you want to try that route.
Well, I contacted Ricks and they said they are not sure if they can help but they'll look and see what they got. Hopefully they can come up with something cause right now my reg amd rectifier are just hanging there. I built the electrics box just big enough to fit the single unit...not both individually. At least it works the way it is. Thank you everyone for your help and I'll let you know what happens.
^^^Also, would the early 80's CB one work with a lifepo4 battery?
Yup.
I always recommend that you test it, but all the ones I've used have been fine with the latest gen of batteries.
