1978 1T5 Yamaha XS750 SuperSport - repair, rebuild and fun log.
eMCZe
Hi,
I'm new user from Poland. I bought XS750 and decided to rebuild it for me. I do it for fun from ride and fun from build.
I often read the forum out of curiosity, but now I decided to put your knowledge into practice in my own garage.
Here's the patient, a 1978 Yamaha XS750, bought already in the process of converting to a scrambler...
... when I saw this naked frame I love it and pack it to my truck ...
I bought not only frame with body but with all parts and even more...
At home, took out XS from truck, look at my new love...
... and decided to change the previous owner's plan and that's why I'm here.
Greetings to everyone at DTT,
Marcin
I forgot about my plans for Yamaha... yes it will be kind of cafe racer :cool:
All mechanical parts goes to my friend, he should rebuilt engine and gearbox ( I have original one with matching numbers for parts and second one working ).
I will do all body works, electrical works and other.
Here is the scope of work I have imagined:
- change tires
- clean from the rust and protect the tank
- rebuilt body from tourist to racer
- paint body
- change whole electric to mo.unit
- change front brake system
- change "dashboard"
- rebuilt engine
and more what will born in my head.
Some of the work is already underway, some is already done, and some is still in the planning stages. I hope you enjoy photos and lengthy posts, because that's just how I am.
Regards,
Marcin
I started from tank. Inside was little bit rusty...
First, I rinsed everything with water under pressure and then I poured rust remover over the entire tank overnight. The next day the magic will happen.
Then I filled the tank with resin for tank preservation and repair.
a few days of drying, the fuel tank is ready for another 50 years of life.
Last thing about tank repair. Here it is after a week when the epoxy has completely dried.
I used a system from the German company Fertan. Fedox rust remover and Tapox 2K epoxy resin.
"Tapox 2K coating lasts for many years and, in most cases, provides lifetime protection for the tank. Since it is a hard, chemically cured epoxy resin, once fully dried, it becomes an integral part of the tank and does not undergo biodegradation or dissolution by fuels."
It's important to note from my observation, that if you want to use this, it should be done only before preparing and repainting the tank. The resin is so dense that removing it from the tank is almost impossible without staining the surface.
Good looking start! That should be a nice bike.
Thank you very much... and I hope.
Before I post more about tank few words about engine.
Previous owner bought XS fully working, maybe not perfect but working. When I bought from him engine was removed and open. It good reason to overhaull it.
First we checked both cylinder blocks and cylinder heads and we chose the better ones
measured cylinder liners and were almost 0,1 mm more than new, I decide to buy new +0,25 pistons and pistons rings set.
tomorrow engine parts goes to sand blasting, after that to the workshop, which will grind the sleeves for new pistons and renew the cylinder head.
In the meantime, my engine guy will check what else can be used from this
and what needs to be ordered new :rolleyes:
Dash... XS has standard like most 70/80 bike. Two clock with lamp panel beetwen.
I want to change it, one central speedo and below one digital bar with tacho and indicator. I started by disassembling it into parts.
Because speedo metal ring was bend I used ring from tacho and polished it.
I cut double clock bracket and transformed it into one central and welded with speedo cup.
when new dash bracket goes to powder painting I order new foam for clock, old was completely degraded.
Time for daily dose of my XS... If I write or rather post too many photos, please let me know.
My custom speedo back from paint shop with new powder coat
I like it.
There's probably no such thing as too many photos on DTT!
you shouldn't say that - I checked my disk drive and I have over 1000 photos from work on XS ;) I bought it 2 months ago :rolleyes:
I've already done a lot of work, but I'm presenting it in small pieces so that it will last longer.
News from now. Today efore cylinders head goes to glass blasting was disassembled and the intake channels were aligned.
Back to fuel tank...
Yama was green but before, from new... who knows??
I started removing paint and
almost like a rainbow
I thought about just applying clearcoat and leaving it at that.
but I wasn't sure what was underneath, so I removed everything. That's good, because there were dents under the paint. On right top
and right side
rest of surface was in good condition
I started repairing it and preparing it for painting.
I can understand thinking about just clear coating over what you had. That really wasn't bad looking. I am sure you made the right choice, though.
As you could see, I cleaned everything down to the bare metal.
One of the reason was my helmet. I have Hedon Heroin Racer White Knight and I decide to go this direction.
I almost finish work and you will see soon.
XS as touristic motorbike has long seat and long frame.
I want shorter, mayby only driver seat. I cut frame behind shock absorber mounts.
I will weld frame loop but first need to know what seat I use.
back to the tank...
First, I smoothed out the dents.
On the bottom, I used carbon fiber putty to create a strong yet flexible layer. You can see its black color. The second layer, green, is standard putty.
The next step was the first coat of 2K epoxy primer. The entire piece was lightly coated with black varnish and sanded to reveal any remaining imperfections. When these appeared, especially on the edges of the black and green filler, I used a fine filler. This process was repeated several times until the surface was even and smooth.
If you've seen my helmet, you already know that the 750 body will be white. I choose Mazda Crystal White base, aply few layers
and first light layer of 2K clear coat to close the acrylic base
Of course, this is not the end.
Maybe something about wheel now ??
I bought it with Conti TwinDuro 120/90/18 rear and 100/90/19 front.
Perfect for a scrablem but I want racer.
I decided to buy some classic road tires. and bought Shinko E270
with bigger size... 4,5-18 rear and 4,0-19 front. It's maximum for thr drive and the fork.
now both wheels has the same diameter
One more time XS with old tires
and new
look badass !!! I love these balloon tires
without engine had to add a piece of wood because now the frame is higher above the ground, and it's not the only problem.
I hope that you want more logs.... ups, maybe not.
Those balloon tires are seriously cool.
Thanks,
I wrote about bigger size, on rear wider tire has no place, my 4.5-18 is maximum
I front problem was with front fender, wheel was to high
I need modify bracket and... cut it because want something short in my project
first cut
remove chrome layer for primer and putty
Here with new longer mounting bracket and white base
and first fitting on bike
It's not the end... with body paint.
