1978 CB125s front brake swap
maireeka
Active Member
I'm working on getting my cb125 going, and was messing with the front brake. It is a mechanically actuated disc with 1 pot and circular pads (tiny). I took it apart, cleaned it up, greased the piston, put it back together. It still doesn't work for shit. Tried again, and nothing. They will squeeze but they will not let go. I was wondering if there was a simple swap to either a drum from another cb model, or maybe a hydraulic caliper I could mount to the disc that I currently have.
If not, then is there anywhere I can get some kind of rebuild kit for the piece of crap front brake that is on my bike?
If i get this baby running, I'm going to be hard pressed to not take her out for a test ride with just the rear brake...
If you get rid of that wheel and brake set-up, I'm interested. PM me offline to discuss.
--Thanks, Chris
make sure the Brake wire is not binding in the wire housing. i would try and pull the sucker apart and clean it, or you could just take it off the bike, shoot brake cleaner down it, work it around, then use some WD40 and work it in. also... make sure your line has very gentle curves... that also might make it bind
I was also having a hard time finding a replacement for my front brakes on my CB125S. You can get most of the parts to rebuild the caliper from your local Honda dealer but they're really spendy. You could also swap front ends. The Rebel 250 should bolt right on and give you lots of options for brake replacement. I took a different approach. I just took them off since if you ride properly you'll hardly use them anyway, and it gets you back to the whole ideology of cafe bikes. Less weight, fewer nonessential parts blah blah blah. Plus it looks pretty damn good without that huge ass rotor on the front.
