1978 CB400T Type II NO ELECTRICS
kroaks
So I started my first project bike, a 1978 CB400T Type II. It's been fun so far and I've leant a lot but now I have hit a snag with the electrical and have no idea what to do. I have zero electrics. No lights/horn/starter/etc. Nothing. As far as I can tell everything is properly grounded, the battery is new and works in my other bike. I've even tested all the wires in the harness to see if any were broken and checked the starter button. Everything checks out. I had been using a Clymer manual, until I came across a Honda specific shop manual, which was WAY better. But still I can't seem to get anything to work. Any suggestions would be great.
First post usually gets better answers if poster introduces themself... Not to come on harsh, just a tip ;)
Welcome to the site! You will find numerous topics regarding your problem.
It can be about anything, but as you say your battery is good, your wires are good and you have no power, it must be the fuse next to the battery. You can locate it by following the red wire from the battery into the harness. It should be present there, in a plastic container around the wire.
First timers often mistake 'checked and good' for 'i guess it's good' - check it, never assume.
