Cooter1979
Hey guys looking for some help/suggestions in which direction to go with jetting my VM32's from Dim City Cycles.
History, I rebuilt the bike last year new ring gaskets re-seated the valves and had the stock carbs rebuilt. I also added a MAC 2 into one exaust. I spent all last summer fighting with leaky, flooding, all around crapy carbs.
So this spring I got 2 new VM32's but I'm running way to rich I've gone from the 185 main 35 pilot to 170 main 25 pilot set the needle to the leaneast postion. The top end 1/8 throttle and above is better still a little rich but the low end is a mess kinda floods out and stalls.
If I shut off the fuel or pinch the line the bike leans out and the idle jumps from 2000 rpm to 3500-4000. I've tried backing the air screw out past 3 turns it gets better but still to rich.
Do I go to a smaller pilot or can I change the air jet? Should I be changing the needle jet and jet needle?
I'm hopeing some one on here has put these carbs on a CB400T before.
Thanks in advance for any help.
