1978 cb550k cafed !!! ON THE ROAD !!! done for now...
should i go flat black on the tank and seat with high gloss white checkering, or high gloss silver w
  • flat black with h.g. white
    Votes: 1 25.0%
  • h.g. silver n h.g. black
    Votes: 3 75.0%
  • Total voters
    4
Re: 1978 cb550k cafe *it has knee dents*
thanks for the motivation! i am soldering more leds in the brake light on my coffee table at home right now. then fixing the left hand control wiring too.
- later finnish sanding 4 small spots on the tank then it will be ready for paint.
also i have polished out the thicker linkage/arm to the rear brake drum....looks like a mirror.
can't wait to take pics of this thing done!
some more of the harness work.
thinking silver joe.
the book sucks...parts break down from bike bandit does not show enough,so...
i have a request.....might be a big one but, i have a problem right now.
i replaced the pressed in seals with ones i made from o-rings and now i cant get the carbs back together because i forgot how everything went together.
the specific areas of confusion are.
- how the linkage of the choke works including little spring.
-throttle return spring set up
-and correct orientation of dog bone(thing that holds 2 carbs together) and dog bone with arm
so please if someone with a 77,78 cb550 could take a few pics i would be very happy.thanks.
Just killing some time tonight and ran across your request....here are some pics of a set of PD carbs from a 78 550k
Silver is tits! ;)
Silver and black seem to be PERFECT Cafe Racer colors.
~Joe
hell yeah. silver and black! maybe some checkers from front to back?
back to the carbies.... but the choke linkage is not so smooth. the smaller spring that opens up both sides 2x2 carbs is really weak and i can not source parts. i am thinking of just doing a small weld to connect the sides together so it opens nice and just be done with it.....any objections? i think it would work fine.
ok parts came in today so hopefully i have time tomorrow to work on this beast!
new seals/orings for top of carbs to stop any old air leaks.
a pic showing where i hope to make the connection solid between the carbs via small weld or nut and bolt
and the carbs with some cool red paint ...it adds like 20 hp.lol!
ok i did not quit on the choke.... finally got it to work after alot of playing with it and winding the sping yet another time.... still is a little laggy in response sometimes but hey no mods needed.
new shifter seal in.
chain and back tire on.
right side crank case cover and starter cover on.
finnishing the electrical to mount that seat. then front tire.
damn main jets are still on there way when i ordered then with the last batch of parts... but they are being shipped usps and not ups for some reason?
we'll off to look at a 1980 Suzuki gs550l tomorrow for my buddy anyone know of some problem areas on these bikes? and what makes a "L" model a "L" model?
later dudes!
main jets are here!!!! alot of work about to happen! she might be running soon.
but i do have to look at this other bike today so that is 2 hours just in drive time.... ::)
but hey you need your boys to help ya tear up the road right?
Re: 1978 cb550k cafe *almost paint time*
this bike is a b*tch sometimes... damn carbs are not so smooth when it comes to throtle action so i am gonna have to take them off again.............damn.
other than that got more done today.
seat is mounted. front brakes done.
now why i have not put up more pics...lol
need to figure out why the lights don't work.
headlight is no power high or low, with no high beam indicator on panel,left turn stays steady on indicator with no flash from bulb.right side works 4.0 and like always someone way messing with this harness before me. >:(
i have a lot of wire chasing ahead of me. kinda going two steps forward one step back. do to finding problems with original equipment i.e. the brake bleeder that came from hell too.
Re: 1978 cb550k cafe *the electrical retard*
ok finally chased all the opens down. highlight is great, electric start, flashers, indicator lights...good to go. starting the rear set build next. also i will through primer down on the tank and seat till it get paint going. finals are here too so what does not get done tomorrow will have to wait for a little bit. later
Re: 1978 cb550k cafe *rear sets here we go*
Projects lookin good so far, let us know if you need any help with the rear sets.
What happened with the GS? The "L" model has the cruiser shaped tank and the older Zooks are known to have charging problems.
