Losmanja
Ive had the bike for a couple months now. Just been working slowly, tuning carbs (pain in butt), and getting it to run right before I make it pretty. Its running pretty good now, so I started assembling and mounting seat, rearsets, etc.
Here's some progress so far.
Here she is the day I brought her home. The bike was so clean and nice, I literally stared at her for about two weeks before I could bring myself to chop her up!
Broke it down and worked on engine first. Installed a new cam and electronic ignition. The ignition kept dying once the bike go hot, so after two weeks of fussing and working with cycle x on phone, I went back to points. Sucks, but Im over the headache. Maybe I'll try again and swap the ignition later.
Removed airbox and installed pods. I upped the main jets to 120 and top end is nice. The k8 carbs were a pain since they have a fixed slow jet and fixed pins. Low and mid was fixed (somewhat) by putting a washer under the pins to lift them a bit and playing with fuel screw. It runs at an acceptable level once fully warmed up.
Now that the motor is working the way I want it, I started chopping off tabs and all the pieces I didn't need on the bike.
Used some wood to mock up a pan for electronics under the seat. Ill change it out once I am done with everything.
Ran new wiring to extend everything under seat bump. No starter. Kick only. Installed a Carbon Speed battery to charge everything when kicking and keep lights steady at idle. Everything fits nice under seat bump.
4 into 1 pipes. Mounted carpy seat. everythings is as it should be.
I didnt like the oild tank and most aftermarket ones had thin lines, so I had Rob at Elswick Cycles make me a new oil tank. Looks much better I think. It really opens up the back of the frame.
Put some oil in there and Im ready to ride!! Kicked it over a few times and BAM! Kickstart broke my raask brake lever. Back in the garage it goes
Talk about a downer. Now I have to order a new brake lever, and a new curved kick pedal and hope it clears. One more week waiting on mail before I can ride it. Gonna be a long week.
