mmaurin
so i ground down and sanded the foam...
got the correct pigtail for the markers, grounded to the seat pan
hooked the hot wires for the run and stop light to a two part trailer connection and ran the wires between the foam and the pan
heres the a better pic of under than pan and how the two markers orient...
for the turns i drilled and tapped the frame to ground them and then ran the hot wires down the rails... im going to do the wires correctly eventually but for now everything is connected with crimp connectors and electrical tape as a cover... i think ill put some miles on it before i finalize it all
and if i go with the mexican blanket this is what it may look like... too busy...
but really i think ill upholster the seat because the form looks pretty sweet to my eye... the batting will help even out the tail section of foam which is cobbled together...
