1978 Kz200
Gramby
GOB was learning life lessons all over the place.
Hi, Team.
So here's my project. A lot of this is me learning as I go, so I'll be posting in the various threads looking for advice.
Here's what I know of the bike. I bought it from a neighbour a couple of weeks ago. He removed the airbox and added a pod filter, took off the mirrors (one of which I've put back), the gauges (he actually broke the frame that held the speedo and the tach together and just installed the speedo), the front fender, and trimmed the seat. He painted the tank a flat black, put on some knobby tires (which I like), and chopped the muffler. He put the battery behind the engine, so it's just kind of sitting there with a bungee cord holding it in place. He also removed the old handlebars and put on some motocross bars instead. Also, the starter button doesn't work, so kickstart only.
Here's a video: https://www.youtube.com/watch?v=WcXychLdtkE
The bike does run and drive (quite nicely, actually). The major problems I have are these:
1) The headlight flashed and then went out when I started it up last week. Now none of the lights work. Brake lights, signals, etc. The fuses are still intact and the horn works (only when the bike is running). So I'm wondering how much I'll need to rewire, and electrical stuff makes me nervous because I have the least experience with that (meaning none).
2) The engine runs rich (I get carbon fouling on the plugs, so my understanding is that's a sign of running rich). I'm assuming, as I say in the video, that the previous owner didn't re-jet the carbs when he added the pod filters, but again, I don't know for sure. I used to own a Honda CX500 (first bike), so I've cleaned carbs and done valve adjustments on that, and I'm guessing it's probably not that different on this little baby.
So here's what I would like to do:
A) Fix the carb/rich issue.
B) Get the lights working again.
C) Organize the wiring so it isn't just all over the place.
D) Strip the paint off of the gas tank and put a clear-coat on the bare metal.
E) Replace the headlight with one of those cool Speedo-In-Headlight deals. I've seen old Ural ones on Ebay for around $150, and I'm guessing I could make that work.
F) Replace the dirt bike bars with drag bars.
G) Replace the seat with a nice, brown leather tuck-and-roll seat, but I can wait on that.
Anyway, here are some pics that might help tell the story.
If any of you have suggestions, I definitely welcome them!!
Looks like a fun little toy. Pod will make you run lean, not rich, as it increases the airflow. It generally only affects your main jet circuit as well. At least it starts and runs - then you can troubleshoot from there. Do some digging and find a factory service manual, don't bother with a clymers or Haynes. It's tough to tell from the video but usually people lower the bars and don't shorten the cables, so you'll be needing to do that in order to get em routed properly.
Here are some pictures. For some reason the last time I tried to attach them they all posted upside down. Anyway, here's some of the wiring job:
Shame so much is missing body work wise, these look nice with the tail piece and side panels.
A front mudguard to brace the forks would be a good start.
Great little bikes these, especially in Kawasaki racing green!
