1979 CB750
Basement rat said:
I got a swinger I could sell you, I bought it to stretch before I went the rout of my boxed aluminum one.
I actually have a spare that I found locally ($30), and it has the tapered bearings that my bike lacks. So, it's not really too late to try raising the rear end. It would just add to the cost of the build.
while waiting on the cdi boxes. i have a my Cb650 to tear apart and use for parts and im trying to figure out a way to do a dual disk conversion.. Any suggestions?
vrup pup vrooom! sputter....
so i finally got the carbs i bought to work. they were in ok condition. After playing around with it and rebuilding it a few times i finally got her to idle, run and rev perfectly. This morning before work i wanted to double check my work so i started her up and oil started sputtering and spraying on my wrapped headers :[ Time to replace a few seals.
Once i get my camera back, ill upload a bunch of new pics
Got a few updates here. Finally got the bike running perfectly after taking out the carbs 6 times, but of course i found another leak. Its leaking out of the gear shift lever. i should have that finished up soon. I sent my bike into paint and upholstery today. i think i may go with the balboni lamborgini
2010-Lamborghini-Gallardo-Balboni-Edition-by-Anderson-Germany-Front-Side-Pictures.jpg
here's a few updates on the bike. on the next picture i have my battery tray. i had my welder weld me a bracket where i can just snap the battery in
in the next pic u can see the collars i welded for the seat
and in the this last pic i have....
06 gsxr forks ;)
Those gsxr forks and lambo colors are gonna be hot. That battery tray is clean too. It is cool as hell that you live close enough to Carpy to go to the source for parts. Is he gonna knee bash your tank for you?
yeah its cool carpys near by, hes really helpful with info. i talked to him a lil bit about the knee dents. he made one before for a dohc 750, its on his website. he said he took him a shit load of hours to finish it. he's really super busy, i might have a buddy of mine do it for me.
yeah ill be using a gsxr triple. i probably wont go with the stock one. I want to get an aftermarket one so it doesnt have the suzuki badge indentation or ignition holder.
something like the pic below or something similar.
still waiting on paint and upholstery right now.
heres wat ive done since then....
nothing ahah
well theres this...
so here's what i have so far. the lighting was bad in the garage.. but this is what i managed to snap
url]
im upholstering it up tomorrow because the paint is still a lil tacky. i should have more pics this weekend
paint and upholstery is finally done. im getting rid of the clubman bars(its on upside down because it wont clear the gas tank) and opting for clipons which will give the front end a more aggressive look. im lowering the headlight bucket and moving the tach down as well.
Im still waiting on parts for the gsxr front end.
Ill get better pics up when i bring the bike to the photo booth at work. Im glad im almost finished, just ned to clean up the motor and new rear shocks and so on.
Nice! I was working on a new template for my tach bracket this evening. Mine is set up like yours, in the center. My original bracket was too high and looked weird from full frontal and side view. Do you have a close up of your bracket?
I'm curious to see what you guys figured out for this. I just made a tmeplate for mine but havent actually made the real thing yet. Maybe 3/16" steel plate so it won't vibrate so much. I plan on making/buying two 2" long spacers that mount to the top triple from underneath.
Nice work . I think your speedo mount will work just be sure to add rubber insulators to absorb shock or it will fall off and/or malfunction. I notice you didn't dent the tank. I can tell you from experiance knee dents and the bodywork it takes to make 'em look right takes anywhere from 10-20 hours.If you have limited bodywork experiance double that estimate. And love the color scheme
Wow, that's the shape mine took, except I had a hole drilled off to the side for the choke and a cutout for the ignition/lock.
Second that on the time to do the tank! I had fits with mine and had to basically re-do my dents as the first version didn't follow the line of the seat very well.
That pinstripe really makes the paint job man. Looks great!!
