1979 CB750F dohc project
Well I made some progress cut the back section off and got my triple trees figured out from the gsx suspension swap it's starting to took pretty good next up making sure my sprockets line up and building the mounts for the mono shock!
I picked up my gsxr carbs on ebay for like 130 bucks. They are mikuni bst38ss that came off a 87 gsxr 750. I do believe you can use all of them from a bst34ss up to the 38. I have the first gen of them and they work pretty good but from what I have heard the later version was a little better. Other than the fact that the spacing is different on that rack, they were pretty easy to get running smooth.
Check out this link if you want to learn more
http://www.cb1100f.net/modules.php?name=Forums&file=viewtopic&t=41909&start=0&postdays=0&postorder=asc&highlight=
The DOHC site is going to be a good resource for you on this build. Those guys know their shit.
Well after a few weeks of getting stuff around the house done. I got to work on my bike again I got tabs built and welded in to place for the mono shock and engine back in to continue mocking up things
You're going to want to brace the hell out of that shock mount.
Is that a rear wheel up front?
I wasn't done with the mounts quite yet I was still planning on bracing it up and the wheels are stock on a 90 gsx600 that's where the forks and read swing arm set up are from
What's the difference in the wheelbase from this set up from the original? Looks wayyyyy long.
The swing arm is a 10mm extended haha
But Seriously it's 4 inches longer to the center of the rear axle 6 inches overall so it changed the look of bike quite a bit
