Yup, did my C10 about 6 years ago when the crate motor went in (my Fbody about a decade before that).Something I’ve learned with these SBC’s is you can gain horsepower with the rockers. Now installing a set of 1.52 Comp Cams roller rockers. No more stamped rockers.
Crate motorYup, did my C10 about 6 years ago when the crate motor went in (my Fbody about a decade before that).
Just having the roller tip is kinda irrelevant though, without the roller cam/lifters/fulcrum. But the extra .02 doesn't hurt. Like tossing in a slightly bigger cam.
Shame you had to remove your hood though![]()
Yup, plain ol' run of the mill replacement truck block 350. Works great and gets the job done. But I can understand how some people want theirs to be bigger.Crate motor.
Yea... Duh... That's why I did it to mine. Even a little bit helps. But the full potential isn't realized until you go full roller. I went full roller with the motor I built for my Fbody. You'll see if/when you eventually get there.The stamped rockers also flex, so there's an hp difference in construction alone. They still reduce friction at the valve tip, so it's still a performance upgrade.
Yup, panel alignment is easy, and there are techniques you can use that'll have them "self align" during reassembly. Zero minutes spent "lining up". You should check into them. But I was just bustin your chops as my hood rotates completely out of the way. Didn't/don't need to remove it at all to pull the engineAs far as the hood, if you know what you're doing it's nothing. It took me all of 10 minutes to get it back on and lined up by myself.
Oh yeah, just busting back. I considered the crate motor, but once I decided the block I had needed an 030 bore, I figured I might as well do the 400 crank and go full stroker. Full admit to learning a bunch as I go along. Lots of hidden tricks with these lego motors that we don't get to play with as much with the motorcycles. I also admit that I ran out of money, so that's the real reason I am putting certain things off and buying them as I get the extra cash along the way. It would be nice to be fully suited by the end of the summer. Still trying to figure out the best carb situation and/or eventually EFI or TBI. Ordered a 750cfm Demon that I'm still waiting on after 10 days.Yup, plain ol' run of the mill replacement truck block 350. Works great and gets the job done. But I can understand how some people want theirs to be bigger.
Yup, panel alignment is easy, and there are techniques you can use that'll have them "self align" during reassembly. Zero minutes spent "lining up". You should check into them. But I was just bustin your chops as my hood rotates completely out of the way. Didn't/don't need to remove it at all to pull the engine![]()
