1979 CM400T
Engine
Well after staring at the engine sitting on a couple of 2x4's on the floor, I decided that i had no good reason for not bolting it back into the frame. So that's what I did. The carbs are also hooked back up and the throttle cables are adjusted. Still don't have the right side cover on yet. I'll post some pics tomorrow.
It took me a while but I got a picture of the motor in the frame.
I've got a bunch of parts on the way. A seat from Roccity, wheel bearings and braided stainless steel brake hose from Z1, and 2 new sprockets from sprocket specialists. I went with a 37 tooth rear sprocket, a 2 tooth jump from stock. Now I've got to find a chain for it.
So, the engine's in, wiring hooked up, and the chain guard painted and installed. The weather should be good this weekend so I should be able to repaint my exhaust (it got scratched up over the winter.) After these parts get here and installed I'll almost be done.
Just got some parts in today! I've put the new wheel bearings and dust seals into both the front and back wheels. I also installed the new SS brake hose and got the front wheel put back on. Waiting on the new sprockets before I'm able to put the rear wheel on. Tomorrow I'll go to the shop to get some brake fluid to get the front brake working and I'll also pick up some motor oil so I can start up the engine. Oh yeah, since the weather was nice enough I was able to paint the exhaust as well and I'll be able to install it tomorrow.
Thanks, the shitty pictures don't really do it justice. When I get this thing done I'll be getting some good shots of it.
I've got the exhaust painted and installed. Today I'll be picking up some oil and brake fluid so I can start up the engine and get the front brake working. Still waiting on the sprockets and the seat. I'm more than halfway done getting the gas tank ready for paint. I think I'm going to try some rustoleum rattel can on it rather than brushing it. If it comes out like shit I can always paint it again. I'll post more pics when I make some progress.
I got my sprockets in. Mounted them both up yesterday and I got the rear wheel back on. So it finally has its legs. I got my seat from roccity last night. It is very nice. The finish is very smooth, there are no pin holes or any other imperfections in the seat. After I get the mounting brackets sorted out all I'll need to do is paint it. If anybody needs a seat, get one from roccity. His prices are great and his work is awesome. I put the tank on with the new seat to see how everything would look. I ground off the old seat mounting tabs to make a little bit more room for the seat. It should be very easy to repaint that part. One of the advantages of using a paintbrush to paint your frame.
This is picture of the seat mount in progress. I making it out of an old piece of shelving.
I've also started work on a blasting cabinet made out of a 55gal drum. So far I've only spent about $15. The plan is to make an entire blasting setup for under $50.
You may want to try a 4" foam roller brush for the paint. Used it on a car that I painted with great success. Decided to try out the $50 paint job I had heard so much about. Cost a little more than $50, but much less than any other option. May do the same with the XS, but we'll see.
I've heard good things about those little foam rollers. I don't know how great it would work on a frame because it has a whole bunch of little pockets and folds that I think might make it difficult to get a roller into. The paintbrush worked out pretty well.
Won't start
Ok, I got the gas tank cleaned up and I put it on the bike with a bit of gas in it. The engine turns over just fine, the starter is fine, but it doesn't run. I pulled the plugs, they're giving a nice blue spark. They were slightly wet and smelled like gas. They were cleaned and gapped last week. I tried several attempts with the choke, several with the choke off. The carbs were cleaned and inspected prior to putting them back on the bike about 2-3 weeks ago. The only thing that I can think of that's screwy is the kick starter. The arm is really tight and difficult to push down, and does not want to come up on its own. It needs to be pulled up. I'm going to be taking off the side cover soon any ways because I've got a small oil leak so I'll check it out. Does anybody have any ideas?
did you sync the carbs? is it chugging or trying to turn over? what about your points how do those look have you set those?
The bike's in the basement, probably about 50-55 deg down there. The bike doesn't have points. I haven't synched the carbs because the bike isn't running. The carb settings are the same as when I took the carbs off the bike when it was running. I've really cranked the hell out of the engine with no success.
wow no points huh... so it is electronic... make sure your getting fuel, loosen one of the float bowl drains to see if there is fuel in there... if there is, then check spark (which you did), then you need to chase wires man, make sure your grounds are all good and solid
I finally got it to run for a second. It needed a whole lot of throttle but it was going. I couldn't keep running it because the basement was filling with exhaust :D At least it's a starting point. I took off the engine side cover sidecover and reinstalled it with new gasketmaker to fix a small oil leak. The kickstarter wasn't working right because I didn't lube the oil seal previously. I fixed that when I replaced the cover. I'll fill it back up with oil tomorrow, bring it outside and see if I can't get it running for a while. I think I'll need to get some fresh gas in it to get it running smoothly. I'll order a chain tomorrow and hopefully, when I get it installed, I'll be able to run it around the driveway. That is, of course, if I can get it through the snow in the yard. Thanks for all the help, guys. Oh, I've almost got the seat mounted. I'll post up some pics when I've got it done.
watch none of the gasket maker comes off inside, that is how I lost the right piston, plugged up the oil channel. Lookin good, I like the seat, I might just save up for a rock city instead of trying to make one.
Like the yellow too.
Cheers.
+1 on rock city man... i have almost 65 bucks in materials into my seat and it is not even done! wish i would have just send the 100+ to him to get it ready for paint!
Yeah, I'm really hoping that none of the gasket maker comes apart inside the case. I was pretty careful with it. Building my first seat was definitely a good experience but it was an expensive one. Roccity gives out DTT discounts on his stuff. I think I paid $90. You really can't beat that. The paint on the tank is just rattlecan rustoleum that I'll be cleaning up a bit. I'm planning to put a couple of coats on with a brush, too. I kinda like the brushed on look. It adds some texture to it that makes it unique.
