1979 Honda CB750: Carburetor Rubber Gaskets
jnguyen07
Hi All,
Took my carburetors apart for some cleaning and noticed that the rubber gaskets are pretty much done for. I've had trouble finding just the gaskets themselves. As a result I was considering using a tube of gasket maker.
Does anyone have experience with this by any chance? I'm still learning and don't know a whole lot, but I've heard that everything with the carbs are super sensitive. Think using this gasket maker would be ok? Any help is always appreciated. Thanks in advance!
- J
Check around, o-ring kits can be found. DO NOT use any tubes gasket makers(i.e. Permatex) in your carbs.
alrighty...thanks for the help! I guess I'll have to look a little harder.
Westernhonda.com bikebandit.com are OEM suppliers of parts. Go to the part fiche, enter your bike and use the blow up diagrams for what you need. If all fails this can be a reference for the size you need to look elsewhere.
If you are looking for kits, I don't see any o-ring only kits on eBay.
if the gaskets are still able to fill the groove in the bowl then loctite 518 flange sealant is perfect for the job
it is handy stuff to have around anyway by far the best flange gasket eliminator sealer thread sealant out there
permatex also makes an equivilent and it is safe for carb work,anerobic
XB, thanks for the input. I wasn't aware of that sealant.
Also, I think when he says "rubber" gaskets, he may just mean o-rings and not just the float bowl gasket.
yeah it is not like silicone, it like magic ;)
i should work for them i talk it up so much but it really is amazing stuff
Actually it is the float bowl gasket....although I am a total rookie here and did not even learn that term until after this post when I did a little more. Thanks for all the input fellas. I actually got a little nervous about permatex so ended up ordering a set of float bowl gaskets on ebay. Although I found out the leak was occurring both from that, as well as a faulty float. One of them wasn't doing its job but I was able to adjust it a bit and stopped the leak.
Now as soon as I start the bike, its idling at like 4k! any suggestions?
